Infinite reload of STANDBY FWSM unit due to incorrect configuration replication from ACTIVE FWSM unit - 2nd attempt to get help
Dear Cisco Experts and Cisco experienced persons!
I'm not receive any definite answer for my question, so I'm repeat this thread:
This is a failover problem. We have A/S FWSM failover configuration (ver. 4.0.6 each)
This problem suddenly appears when our ACTIVE unit configuration reached 125K in size. STANDBY can't load this configuration, because it's incorrectly
recognized ACL entries (detect some strange mistakes), and this happened each times in different locations. And after that STANDBY unit is reload. And this is the cycle process:
1-st reload:
Aug  x 02:08:01.172 MSK: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimal Diagnostics...
SW2#
Aug  x 02:08:04.260 MSK: %MFIB_CONST_RP-6-REPLICATION_MODE_CHANGE: Replication Mode Change Detected. Current system replication mode is Ingress
Aug x 02:08:04.300 MSK: %SNMP-5-MODULETRAP: Module 4 [Up] Trap
SW2#
Aug  x 02:08:03.952 MSK: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
SW2#
Aug x 02:08:07.975 MSK: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
SW2#session slot 4 processor 1
The default escape character is Ctrl-^, then x.
You can also type 'exit' at the remote prompt to end the session
Trying 127.0.0.41 ... Open
FWSM# Beginning configuration replication from mate.
Access Rules Download Complete: Memory Utilization: < 1%
Config Sync Error: Following command could not be executed on standby
         access-list XXX commit-status commfttgl ,hne 93 extended permit object-group DM_INLINE_SERVICE_19 host me host you
Context: single_vf
******REPLICATION OF CONFIGURATION FROM ACTIVE TO STANDBY UNIT IS INCOMPLETE,
TO PREVENT THE STANDBY UNIT TAKING OVER AS ACTIVE WITH A PARTIAL CONFIGURATION,
THE STANDBY UNIT WILL NOW REBOOT*******
[Connection to 127.0.0.41 closed by foreign host]
SW2#
Aug  x 02:08:59.764 MSK: %SNMP-5-MODULETRAP: Module 4 [Down] Trap
SW2#
Aug  x 02:08:59.764 MSK: %MFIB_CONST_RP-6-REPLICATION_MODE_CHANGE: Replication Mode Change Detected. Current system replication mode is Egress
SW2#
Aug  x 02:08:59.739 MSK: SP: The PC in slot 4 is shutting down. Please wait ...
SW2#
Aug  x 02:09:14.749 MSK: SP: shutdown_pc_process:No response from module 4
RD2rt16#
Aug  2 02:09:24.761 MSK: %C6KPWR-SP-4-DISABLED: power to module in slot 4 set off (Reset)
SW2#
2-nd reload:
Aug  x 02:10:01.172 MSK: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimal Diagnostics...
SW2#
Aug  x 02:10:04.260 MSK: %MFIB_CONST_RP-6-REPLICATION_MODE_CHANGE: Replication Mode Change Detected. Current system replication mode is Ingress
Aug x 02:10:04.300 MSK: %SNMP-5-MODULETRAP: Module 4 [Up] Trap
SW2#
Aug  x 02:10:03.952 MSK: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
SW2#
Aug x 02:10:07.975 MSK: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online
               access-list MMM commit-status committed line 61 extendek pgzm)u udp Network 255.255.224.0 host she eq ntp
Context: single_vf
SW2#
Aug  x 02:10:59.764 MSK: %SNMP-5-MODULETRAP: Module 4 [Down] Trap
SW2#
Aug  x 02:10:59.764 MSK: %MFIB_CONST_RP-6-REPLICATION_MODE_CHANGE: Replication Mode Change Detected. Current system replication mode is Egress
SW2#
Aug  x 02:10:59.739 MSK: SP: The PC in slot 4 is shutting down. Please wait ...
SW2#
Aug  x 02:11:14.749 MSK: SP: shutdown_pc_process:No response from module 4
RD2rt16#
Aug  2 02:11:24.761 MSK: %C6KPWR-SP-4-DISABLED: power to module in slot 4 set off (Reset)
SW2#
AND so on... INFINITE
Any ideas how to resolve?
Some more information for Magnus Mortensen:
We have two identical WS-C6506 switches with WS-SUP720-3B (s72033_rp-ADVENTERPRISEK9_WAN-M, Version 12.2(33)SXH4) and with one WS-SVC-FWM-1 (FWSM Firewall Version 4.0(6)) installed each.
The configuration of WS-C6506 (firewall related) is identical:
firewall multiple-vlan-interfaces
firewall module 4 vlan-group 570,800,801,809,850,860,900,982,984,986,990,992,993,998,
firewall vlan-group 570  570
firewall vlan-group 800  800
firewall vlan-group 801  801
firewall vlan-group 809  809
firewall vlan-group 850  850
firewall vlan-group 860  860
firewall vlan-group 900  900
firewall vlan-group 982  982
firewall vlan-group 984  984
firewall vlan-group 986  986
firewall vlan-group 990  990
firewall vlan-group 992  992
firewall vlan-group 993  993
firewall vlan-group 998  998,999
Note: all vlans are exists and active
The configuration of SVC-FWM-1 (A/S failover, ACTIVE) (failover related):
interface Vlan998
description LAN Failover Interface
interface Vlan999
description STATE Failover Interface
failover
failover lan unit primary
failover lan interface FWSM_failover Vlan998
failover link FWSM_Statefull_failover Vlan999
failover interface ip FWSM_failover 1.1.1.1 255.255.255.252 standby 1.1.1.2
failover interface ip FWSM_Statefull_failover 1.1.2.1 255.255.255.252 standby 1.1.2.2
The configuration of SVC-FWM-1 (A/S failover, STANDBY) (failover related):
interface Vlan998
interface Vlan999
failover
failover lan unit secondary
Earlier, from time to time, ACTIVE and STANDBY loses it's connectivity:
at the begin:
ACTIVE:
Failover On
Failover unit Primary
Failover LAN Interface: FWSM_failover Vlan 998 (up)
        This host: Primary - Active
        Other host: Secondary - Standby Ready
Stateful Failover Logical Update Statistics
        Link : FWSM_Statefull_failover Vlan 999 (up)
STANDBY:
Failover On
Failover unit Secondary
        This host: Secondary - Standby Ready
        Other host: Primary - Active
Then after some time of many configuration changes via Device Manager Version 6.1(5)F during work time we have such situation:
ACTIVE:
Failover On
        Other host: Secondary - Failed
        Link : FWSM_Statefull_failover Vlan 999 (Failed)
STANDBY:
Failover On
How can we resolve this situation earlier?: we can go to WS-C6506, where the STANDBY unit installed in slot #4, and type the command:
no power enable module 4
    and then two minutes later:
And it works fine for us: after some time STANDBY unit was reloaded and copy it's running configuration from ACTIVE, then communication between ACTIVE and STANDBY  be restored.
But from some time (when configuration on ACTIVE become large enough ~ 125K) this method doesn't working already:
when STANDBY wal reloaded, it's begin configuration replication from ACTIVE, but stopped and begin reload, because such error:
Context: single_vf
The correct line is:
access-list MMM line 61 extended permit udp MMM_Network 255.255.224.0 host 10.10.100.1 eq ntp
The next time parser of replicated configuration at STANDBY stopped at some OTHER line:
access-list XXX line 93 extended permit object-group DM_INLINE_SERVICE_19 host me host you
and so on...
Also, I want to say, that all configuration at ACTIVE unit are correct, without any errors.
Also, we actively use such objects in our configurations:
name 10.10.10.10 me
name MMM_Network 10.10.10.0
and other network or service object groups.
Also, we widely use remarks for our access lists and actively use Device Manager for FWSM configuration during business hours (to improve configuration performance).
All of this are correctly recognized at ACTIVE unit, but can't fully replicate to STANDBY.
How can we resolve this problem without manual load configuration from ACTIVE to STANDBY unit?
With best regards,
Max
Everyone's tags (2)
Re: Infinite reload of STANDBY FWSM unit due to incorrect config
At this point it may be best to open a service request so that TAC can do sone live troubleshooting and get you back up and running.   - Magnus
You can enable "debug fover cmd" and "debug fover msg" to get more insight while the standby is booting and copying config.
Can you check line 61 of the ACL MMM? If you remove that line does the standby come up and replicate fine.
As Magnus suggested, TAC can help with this also.
PK
Dear Cisco Experts!
Now we resolve this problem:
don't use '?' sign in your access-list remarks!!!
Or FWSM unit can't load properly, but with the errors this post described.
With best wishes,
Maxim
I wanted to mention that we just experienced the same problem.
Your suggestion, that the question mark in the description caused the problem, led us on the right way.
We checked all our contexts and found that in our case it was the #-sign which a colleage thought would look nice in a group name. In reality this proved devastating. Once we eliminated the rule with the # in it everything was back to normal!
Until now I haven't found a list with illegal characters for object names or comments.
Many thanks for your hint!
Gold
Hi Beat,
The command reference for 'object-group' provides a list of supported characters:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/command/reference/no.html#wp1636977
Identifies the object group (one to 64 characters)
 and can be any combination of letters, digits, and the "_", "-", "."
characters.
Hope that helps.
-Mike
Thanks Mike, just what I was looking for. I will spread the word...
Beat
1028
