Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
inside to outside ip
 Hi Experts..
I have users sitting on inside and they are trying to access a DMZ server with its outside(public) ip (X.X.X.191) which is static nat but they are unable to reach server. I have allowed same security permit traffic inter & intra interface. ALso have disable spoofing. Still unable to reach. Pls help me out.
object network obj-ANY
 nat (inside,outside) dynamic interface
object network obj-ftp-server
 nat (dmz,outside) static X.X.X.191
Hall of Fame Super Silver
Have you permitted traffic
Have you permitted traffic same-security intra-interface?
If so, and it's still not working, please run:
packet-tracer input inside tcp [user ip address] 1025 x.x.x.191 [server port]
...and share the output
 Hi.. Currently i am trying
Hi.. Currently i am trying to ping this server outside ip to check reachability, here is logs.
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   X.X.X.0   255.255.255.0   outside
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group IN in interface inside
access-list IN extended permit icmp any4 any4
access-list IN remark Allow Domain for Entire Network
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
object network obj_any
Dynamic translate 192.168.110.38/0 to X.X.X.5/18216
Phase: 5
Type: NAT
Subtype: per-session
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
class-map inspection_default
 match default-inspection-traffic
policy-map global_policy
 class inspection_default
  inspect icmp
service-policy global_policy global
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 9
Type:
Subtype:
Result: ALLOW
Config:
Phase: 10
Type: USER-STATISTICS
Subtype: user-statistics
Result: ALLOW
Config:
Phase: 11
Type: NAT
Result: ALLOW
Config:
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 13
Result: ALLOW
Config:
Phase: 14
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 160797423, packet dispatched to next module
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: outside
output-status: up
output-line-status: up
Action: allow
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect icmp
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 9
Type:
Subtype:
Result: ALLOW
Config:
Phase: 10
Result: ALLOW
Config:
Phase: 11
Type: NAT
Result: ALLOW
Config:
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 13
Result: ALLOW
Config:
Phase: 14
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
Result:
input-status: up
output-status: up
Action: allow
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
Phase: 3
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
Phase: 4
Type: NAT
Subtype:
Result: ALLOW
Config:
Phase: 5
Type: NAT
Result: ALLOW
Config:
Phase: 6
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 7
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
  inspect icmp
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
Phase: 9
Type:
Subtype:
Result: ALLOW
Config:
Phase: 10
Result: ALLOW
Config:
Phase: 11
Type: NAT
Result: ALLOW
Config:
Phase: 12
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
Phase: 13
Result: ALLOW
Config:
Phase: 14
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
Result:
input-status: up
output-status: up
Action: allow
VIP Purple
This problem has to be solved
This problem has to be solved by manipulating DNS in a way that the internal users resolve the DMZ-server to the real address instead of the translated address. The users have to access the server by FQDN and not by IP-address.
There are two common ways to get that working:
  1. DNS-Doctoring on the ASA.
    For that you just add the keyword "dns" to your nat-statement:
     nat (dmz,outside) static X.X.X.191 dns
  2. Add the FQDN of the server to your internal DNS.
 Hi,Users need to test some
Users need to test some application running on this server, so they need to check this using only outside ip, so pls how could it work. We are running ASA in HA.
VIP Purple
That can be done with some
That can be done with some dirty NAT-tricks; but really, you don't wan't to do that ... ;-) That's what DNS is for.
Hi, since i have denied
Hi, since i have denied request to this server local ip from inside so i believe DNS option wouldn't work  after adding DNS statement.
Could you share this tricky nat satament to achieve communication through outside ip.
VIP Purple
It will work because in that case you connect to the real IP of the server and not to the translated outside NAT-address.
I don't have a working config for the workaround, but it was discussed on the supportforum before. With a little bit searching you will probably find it.
Hi..I did try adding DNS in
Hi..
I did try adding DNS in NAT statement, after adding it when  i tried pinging this server with its name it was resolving server DMZ ip not outside nat ip. Since as i said above that there is no communication between inside to this server DMZ ip, so i was unable to reach it.
VIP Purple
what is the packet-tracer
what is the packet-tracer output when you use the real IP?
hi..As i said, i have made
hi..
As i said, i have made communication dney  to this serve real ip from inside through ACL as my organization asked me so. This server can be accessible through outside NAT ip only.
So if adding DNS in NAT statement  would cause server name to be resolved with real ip only, then how could we connect it.
Also my client who are accessing this server over internet can also be unable to reach it as server name resolve real ip.
Thats why i am looking for solution which can make this server communication through outside nat ip.
VIP Purple
If you want to communicate
If you want to communicate with that server you have to allow it! And as the server ha a specific IP you have to allow the communication to that IP. For your external users, they have to access the server with the public IP.
Thanks karsten for your help.
Thanks karsten for your help.. i need to coordinate with my seniors on this matter, also will look for workaround which can make communication using outside ip, if you can share that will be appreciable.
On the other hand, could you pls tell me that why i can not reach server outside nat ip from inside, why ASA is not permitting it, actually i need to justify this to my seniors.
Thanks Karsten for your help,
Thanks Karsten for your help, i will be coordinating with my seniors on this, and will look for workaround to make communication through outside nat ip, if you can help me on this that will be highly appreciable.
Also could you tell me why i can not reach outside nat ip from indise, why ASA is denying it. What could be the reason, Actually i need to justify this to my seniors.
VIP Purple
It's the way the ASA works internally. Generalized: When the ASA sees the public IP it decides to route the Packet to the outside interface. And then it's too late for a new decision that the destination is actually on a different interface. The workaround is to NAT on the destination because that decision is done earlier. But that's not the right way to use the ASA.
Thanks Karsten, i have
Thanks Karsten, i have started searching config example for this workaround, it would be very greatful and appreciated if you can share  this.
Hi.. I did try to explore NAT
Hi.. I did try to explore NAT configuration for this problem to could not get successful. Pls help me out sharing config fo this.
107
