Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
inside to outside traffiic times outs
Seem to be having an issue with a firewall I've inherited asa5520
some http downloads seem to be timing out, as well as some websites. When I bypass the ASA no problem.
also have a couple statements and I'm not sure as to why?
outside a.a.a.a
inside b.b.b.b
dmz c.c.c.c
dmz2 d.d.d.d
global (outside) 1 a.a.a.3-a.a.a.98 netmask 255.255.255.0
global (outside) 1 a.a.a.100-a.a.a.200 netmask 255.255.255.0
global (DMZ) 1 c.c.c.80-c.c.c.250 netmask 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0 dns
nat (DMZ) 1 c.c.c.0 255.255.255.0 dns
static (inside,outside) tcp interface 2300 b.b.b.32 2300 netmask 255.255.255.255
static (DMZ,outside) a.a.a.252 c.c.c.1 netmask 255.255.255.255
static (DMZ,outside) a.a.a.240 c.c.c.3 netmask 255.255.255.255 dns
static (DMZ,outside) a.a.a.243 c.c.c.8 netmask 255.255.255.255
static (DMZ,outside) Mail IronPort_DMZ netmask 255.255.255.255
static (inside,outside) a.a.a.247 b.b.b.74 netmask 255.255.255.255
static (inside,outside) c.c.c.c b.b.b.b netmask 255.255.255.255
static (inside,outside) a.a.a.99 b.b.b.98 netmask 255.255.255.255
static (inside,DMZ) b.0.0.0 b.0.0.0 netmask 255.0.0.0
static (inside,DMZ2) b.0.0.0 b.0.0.0 netmask 255.0.0.0
access-group acl_out in interface outside
access-group acl_dmz in interface DMZ
access-group DMZ2_access_in in interface DMZ2
route outside 0.0.0.0 0.0.0.0 a.a.a.1 1
route DMZ2 d.d.d.0 255.255.255.0 e.e.e.253 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:b:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:b:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
1 REPLY
Anonymous
N/A
Re: inside to outside traffiic times outs
You may try changing the uauth timeout. As a trial you may change it to "timeout uauth 01:00:00" and then try downloading. Also you may try removing the inline IPS.
111
