Integrating a secondary failover unit ASA 5510
I have a single production 5510 with 2 contexts.  Now I want to integrate the secondary failover unit. My question is: How much configuration needs to be done on the secondary firewall?  How much of the configuration will be sync'd from the primary to the secondary when the secondary is connected?
For example, do I need to add the following on the secondary or will it be sync'd from the primary?
admin-context NAME
context NAME
  allocate-interface Ethernet0/0.14
  allocate-interface Ethernet0/0.200
  allocate-interface Ethernet0/1.23-Ethernet0/1.24
  allocate-interface Management0/0
  config-url disk0:/NAME.cfg
context CONTEXT1
  allocate-interface Ethernet0/0.104
  allocate-interface Ethernet0/1.500
  config-url disk0:/CONTEXT1.cfg
  • Firewalling
Everyone's tags (4)
1 ACCEPTED SOLUTION
Re: Integrating a secondary failover unit ASA 5510
Hi Greg,
Before I physically connect the standby firewall I should run the: "failover" command on the primary firewall, right?
You can introduce the secondary (standby) device in the network ; however enable the "failover" command on the primary firewall first.
The following line: "failover interface ip ASA-Failover 10.0.1.1 255.255.255.252 standby 10.0.1.2" is configured the same on both primary and secondary firewall, right?
Yes , absoultely correct
Hope this helps !
Ankur
Hi Greg,
As a first step , ensure that the secondary unit is configured in multiple mode and all physical interfaces are unshut  following which you need to just configure the below commands in the system execution space and nothing else.
failover lan unit secondary
failover lan interface FO Ethernet3-> considering that this is the interface you are using for failover link
failover key *****
failover interface ip FO 10.1.1.1 255.255.255.0 standby 10.1.1.2
failover--> enter this command at last
Please go through the below link and navigate to "Secondary Unit Configuration" section under the heading LAN-Based Active/Active Failover Configuration
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a0080834058.shtml
After you enable failover, the active unit sends the configuration in running memory to the standby unit and the complete configuration of the primary (including the one which you have mentioned) gets replicated to secondary unit
Ankur
Thanks Ankur,
Good information.  I have a few more questions.
Hi Greg,
Hope this helps !
Ankur
1483
