interface allocation in ASA cluster multimode
Hi All,
Could someone help this please?
In   ASA cluster multimode ver 9.0, do the cluster control links need to be allocated per context  or do they just require in system context?
TaoLao
Re: interface allocation in ASA cluster multimode
Hi TaoLao
No need to allocate CCL interface to context. Cluster bootstrap configuration will be done only in system context .
CCL interface like failover is configured only in system context.
Got it. Thank you Sujith and Subriyer.
When I configure Data Link I have a message below. Do we have to do any special thing on the ASA
N7K
interface Ethernet1/6
  switchport mode trunk
  mtu 9216
  channel-group 20 mode active
interface Ethernet1/7
  mtu 9216
interface port-channel20
mtu 9216
vpc 20
show vpc bri | be Po20
20   Po20   down*  failed      vpc port channel           -
                               mis-config due to vpc
                               links in the 2 switches
                               connected to different
                               partners
One of ASA
interface Port-channel20
port-channel span-cluster vss-load-balance
interface TenGigabitEthernet0/6
description Data Link (Span Port)
channel-group 20 mode active vss-id 2
interface TenGigabitEthernet0/7
channel-group 20 mode active vss-id 1
Taolao,
You got data-interface and CCL interfaces mixed up. Only data-interface is configured as "port-channel span-cluster" which tells the port-channel it has member interfaces spanning multiple physical devices.
vss-id, too is supposed to be used for data-interfaces.
CCL interface configuration on ASA and N7k should be as below
SW-1
interface Ethernet2/9
  description CONNECTED TO ASA-A Ten0/8
  switchport
  switchport access vlan 500
  spanning-tree port type edge
  mtu 9000
  channel-group 41
  no shutdown
interface port-channel41
  description CONNECTED TO ASA-A CCL
  switchport
  mtu 9000
  vpc 41
SW-2
  description CONNECTED TO ASA-A Ten0/9
  switchport
  mtu 9000
  channel-group 41
  no shutdown
  switchport
  mtu 9000
  vpc 41
ASA
interface TenGigabitEthernet0/8
channel-group 1 mode on
interface TenGigabitEthernet0/9
interface Port-channel1
description Clustering Interface
Since CCL port-channel is individual to an ASA, you need to create a corresponding port-channel on N7k for each of the cluster nodes. For example, on N7k you need to create Po42 for node-B, Po43 for node-C etc.
710
