interface stats: packets dropped
Does anyone know why packets dropped are incrementing on the ASA when you do a show interface command? It's incrementing on all of my ASAs, was wondering if this is normal and could it be from the ACLs denying the traffic therefor showing it as dropped packets?
ryefwpixmain# show int gig 1/0
Interface GigabitEthernet1/0 "inside", is up, line protocol is up
Hardware is VCS7380 rev01, BW 1000 Mbps
Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
Media-type configured as RJ45 connector
MAC address x.x.x.x, MTU 1500
IP address x.x.x.x, subnet mask x.x.x.x
16209696834 packets input, 5283286826326 bytes, 0 no buffer
Received 44485840 broadcasts, 0 runts, 0 giants
102 input errors, 102 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 L2 decode drops
22516121947 packets output, 8248047428881 bytes, 0 underruns
0 late collisions, 0 deferred
0 input reset drops, 0 output reset drops
0 rate limit drops
input queue (curr/max packets): hardware (0/0) software (0/0)
output queue (curr/max packets): hardware (0/0) software (0/0)
Traffic Statistics for "inside":
16207882500 packets input, 4974315252070 bytes
22515355137 packets output, 7828325951984 bytes
177738226 packets dropped
1 minute input rate 13610 pkts/sec, 4831186 bytes/sec
1 minute output rate 19477 pkts/sec, 8261768 bytes/sec
1 minute drop rate, 143 pkts/sec
5 minute input rate 13217 pkts/sec, 4144192 bytes/sec
5 minute output rate 19317 pkts/sec, 7788327 bytes/sec
5 minute drop rate, 147 pkts/sec
Re: interface stats: packets dropped
Dropped packets from ACLs will show up on the show interfaces. To grab more details as to why those packets are dropping, try issuing the "show asp drop" command.
Thanks!
409
