Internet access for LAN user through inside to outside
Here are i want o access internet of my lan users having subnet 172.16.20.0/24
and inside firewall ip is 192.168.11.249/24
outside ip is 125.209.70.88/24
and i also attached a diagram with the ip,s
Navaz
Hi, Below is the required
Below is the required configuration on ASA:-
route inside 172.16.20.0 255.255.255.0 192.168.11.254
Nat  8.2
nat(inside) 1 0 0
global(outside) 1 interface
Nat 8.3 +
object network internal_net
  subnet 172.16.20.0 255.255.255.0
nat (inside,outside) dynamic interface
Prashant Joshi
 I have Cisco Adaptive
I have Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 6.4(5)
But its not working. Below is my configuration and I only now need my LAN user to allow internet through Inside to Outside. One thing is that 172.16.20.0/24 users gateway is 172.16.20.254 similarly 172.16.30.X/24 users gateway is 172.16.30.254 and 172.16.40.X/24 users gateway is 172.16.40.254, 172.16.50.X/24 users gateway is 172.16.50.254. Thanks for the reply.
Version of ASA
ASA Version 8.2(5)
hostname ACTIVE
domain-name dhalahore.org
enable password vXH3rdHwVuRbxQ3j encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
INTERFACE DETAILS
interface Ethernet0/0
 description Inside to the Core Switches 1
 duplex full
 no nameif
 no security-level
 no ip address
interface Ethernet0/1
description Inside to the Core Switches 2
 duplex full
 no nameif
 no security-level
 no ip address
interface Ethernet0/2
 description Public Server - DMZ
 duplex full
 nameif DMZ
 security-level 50
 ip address 10.1.1.1 255.255.255.0 standby 10.1.1.2
interface Ethernet0/3
 description Outside to the Internet via router
 duplex full
 nameif Outside
 security-leLvel 0
 ip address 117.102.8.90 255.255.255.248 standby 117.102.8.91
interface Management0/0
 description LAN/STATE Failover Interface
interface Redundant1
 member-interface Ethernet0/0
 member-interface Ethernet0/1
INSIDE INTERFACE
 nameif inside
 security-level 100
 ip address 192.168.11.249 255.255.255.0 standby 192.168.11.250
CREATE OBJECT FOR LAN NETWORKS
object-group network DMZ-BLOCKED-LAN-NETWORKS
 network-object 172.16.10.0 255.255.255.0
 network-object 172.16.20.0 255.255.255.0
 network-object 172.16.30.0 255.255.255.0
 network-object 172.16.40.0 255.255.255.0
 network-object 172.16.50.0 255.255.255.0
CREATE ACL FOR OUTSIDE TO INSIDE
access-list 102 extended permit tcp any host 117.102.8.90 eq www
access-list 102 extended permit tcp any host 117.102.8.90 eq 8888
access-list 102 extended permit tcp any host 117.102.8.90 eq https
access-list 102 extended permit tcp any host 117.102.8.90 eq telnet
access-list 102 extended permit tcp any host 117.102.8.90 eq pop3
access-list 102 extended permit tcp any host 117.102.8.90 eq smtp
CREATE ACL FOR THE LAN NETWORK TO ACCESS DMZ SERVERS
access-list no-nat extended permit ip 172.16.20.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list no-nat extended permit ip 172.16.30.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list no-nat extended permit ip 172.16.40.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list no-nat extended permit ip 172.16.10.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list no-nat extended permit ip 192.168.10.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list no-nat extended permit ip 10.1.1.0 255.255.255.0 125.209.70.88 255.255.255.248
access-list no-nat extended permit ip 192.168.11.0 255.255.255.0 10.1.1.0 255.255.255.0
access-list no-nat extended permit ip 192.168.11.0 255.255.255.0 5.5.5.0 255.255.255.0
access-list no-nat extended permit ip 192.168.10.0 255.255.255.0 5.5.5.0 255.255.255.0
access-list no-nat extended permit ip 172.16.50.0 255.255.255.0 10.1.1.0 255.255.255.0
CREATE ACL FOR THE DB SERVERS TO DMZ MEMBER AREA SERVER
access-list DMZ-IN remark Allow ICMP from DMZ server to INSIDE server
access-list DMZ-IN extended permit icmp host 10.1.1.254 host 192.168.11.18 echo
access-list DMZ-IN extended permit icmp host 10.1.1.254 host 192.168.11.10 echo
access-list DMZ-IN remark Block connections from DMZ to INSIDE networks
access-list DMZ-IN extended deny ip any object-group DMZ-BLOCKED-LAN-NETWORKS
access-list DMZ-IN remark Allow all other traffic
access-list DMZ-IN extended permit ip 10.1.1.0 255.255.255.0 any
access-list ICMP extended permit icmp any any
access-list SPLIT standard permit 192.168.0.0 255.255.0.0
NAT CONFIGURATION
nat-control
CREATE NAT FOR THE INSIDE USER TO ACCESS
nat (inside) 0 access-list no-nat
CREATE NAT FROM OUTSIDE TO DMZ SERVER(FOR SPECIFIC PORTS OPEN)
static (DMZ,Outside) tcp interface www 10.1.1.254 www netmask 255.255.255.255
static (DMZ,Outside) tcp interface https 10.1.1.254 https netmask 255.255.255.255
static (DMZ,Outside) tcp interface 8888 10.1.1.245 8888 netmask 255.255.255.255
static (DMZ,Outside) tcp interface pop3 10.1.1.254 pop3 netmask 255.255.255.255
CREATE NAT DMZ TO INSIDE(TO ACCESS THE LAN SPECIFIC USERS)
static (inside,DMZ) 10.1.1.0 192.168.11.0 netmask 255.255.255.0
ALLOW THE ACL 102 TO OUTSIDE INTERFACE
access-group 102 in interface Outside
CREATE ROUTE TO THE ACCESS FROM THE OUTSIDE INTERFACE
route Outside 0.0.0.0 0.0.0.0 125.209.70.89 1
CREATE ROUTE TO ACCESS FROM THE INSIDE INTERFACE (ALL VLAN,S INCLUDING APPLICATION,DB,LAN)
route inside 0.0.0.0 0.0.0.0 192.168.11.254 2
route inside 0.0.0.0 0.0.0.0 192.168.10.254 2
route inside 172.16.10.0 255.255.255.0 192.168.11.254 1
route inside 172.16.20.0 255.255.255.0 192.168.11.254 1
route inside 172.16.30.0 255.255.255.0 192.168.11.254 1
route inside 172.16.40.0 255.255.255.0 192.168.11.254 1
route inside 172.16.50.0 255.255.255.0 192.168.11.254 1
route inside 192.168.10.0 255.255.255.0 192.168.11.254 1
TO ACCESS INSIDE THROUGH ASDM
http server enable
http 192.168.11.0 255.255.255.0 inside
http 192.168.11.249 255.255.255.255 inside
TO TELNET INSIDE
telnet 0.0.0.0 0.0.0.0 inside
telnet 192.168.11.254 255.255.255.255 inside
telnet 192.168.10.254 255.255.255.255 inside
telnet 192.168.11.0 255.255.255.0 inside
telnet timeout 10
Navaz
 You need to configure a PAT
You need to configure a PAT policy
General PAT and will be used by all inside users.
nat(inside) 1 0 0
However, if you need to be specific
nat(inside) 1 72.16.20.0 255.255.255.0
nat(inside) 1 72.16.30.0 255.255.255.0
nat(inside) 1 72.16.40.0 255.255.255.0
If still it didn't work, provide me below output :
 packet-tracer input inside tcp 172.16.20.10 5656 4.2.2.2 80 det
Prashant Joshi
Its didnt work. I attached a
Its didnt work. I attached a files that you are required.
thanks
Navaz
configuration seems to be
configuration seems to be fine with ASA, packet tracer showing correct outputs.I
believe packets are not reaching the ASA.
Kindly provide me below captures.
cap capin interface inside match tcp ho <host ip> any
cap capout interface outside match tcp any any
sh cap capout
sh cap capin
Prashant Joshi
Please find the attached file
Please find the attached file . But in Inside interface of ASA a core switch 3750 exist and after that layer 2 switch 2960 exist where the LAN exist.
Navaz
As expected internet traffic
As expected internet traffic is not reaching the ASA, we can see only telnet traffic
( to ASA inside interface).
Have you configured a default route pointing to ASA on your 3750 switch ?
Prashant Joshi
These are the routs add for
These are the routs add for at the core switch 3750
ip classless
ip route 0.0.0.0 0.0.0.0 221.120.216.153
ip route 5.5.5.0 255.255.255.0 192.168.11.249
ip route 10.1.1.0 255.255.255.0 192.168.10.249
ip route 10.1.1.0 255.255.255.0 192.168.11.249
ip route 172.16.20.0 255.255.255.0 192.168.10.249
ip http server
DC-Core1(config)#  do sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     5.0.0.0/24 is subnetted, 1 subnets
S       5.5.5.0 [1/0] via 192.168.11.249
C    192.168.10.0/24 is directly connected, Vlan10
     172.16.0.0/24 is subnetted, 5 subnets
C       172.16.50.0 is directly connected, Vlan80
C       172.16.40.0 is directly connected, Vlan70
C       172.16.30.0 is directly connected, Vlan60
C       172.16.20.0 is directly connected, Vlan50
C       172.16.10.0 is directly connected, Vlan10
C    192.168.11.0/24 is directly connected, Vlan11
     10.0.0.0/24 is subnetted, 1 subnets
S       10.1.1.0 [1/0] via 192.168.11.249
                 [1/0] via 192.168.10.249
Navaz
Below route is punting all
Below route is punting all the traffic to   221.120.216.153 , so we need to delete this route ip route 0.0.0.0 0.0.0.0 221.120.216.153
no ip route 0.0.0.0 0.0.0.0 221.120.216.153
We need to punt all the default traffic to ASA, so add below route.
ip route 0.0.0.0 0.0.0.0 192.168.11.249
in addition, if 172.16.20.0/24 is a directly connected network on 3750 we don't need below route
Prashant Joshi
Thanks its working. but now
Thanks its working. but now next step is to only allow outlook traffic from inside LAN to outside.
Navaz
You need to allow whatever
You need to allow whatever subnets and respective ports you need...for example:-
access-list inside_out per tcp 172.16.20.0 255.255.255.0  any eq 25
access-list inside_out per tcp 172.16.20.0 255.255.255.0  any eq XY
access-list inside_out per tcp 172.16.20.0 255.255.255.0  any eq  YZ
access-group inside_out in interface inside
Prashant Joshi
Thanks josh but its not
Thanks josh but its not working.
I also different acl. can u verfied that its not create the prob
access-list 102 extended permit ip 5.5.5.0 255.255.255.0 any
access-list no-nat extended permit ip 10.1.1.0 255.255.255.0 117.102.8.90 255.255.255.248
Navaz
Above access-lists are allowing any source to access destination 117.102.8.90 on specific ports, rest all other destinations are restricted.
All these access-lists are used in NAT Exempt from specific source to destination.
DMZ access-lists blocking connection to DMZ-BLOCKED and allowing 10.1.1.0 /24 to access anything.
You need to apply these access-lists on interface as well.
access-list <access-list name > in interface <interface name>
Prashant Joshi:-
After these applying, then i
After these applying, then i can allow only outlook traffic and my outlook port are configured at SSL port 995 and 465
Navaz
Add below access lists with
Add below access lists with whatever source and destination you need to restrict
access-list 102 extended permit tcp <source>  <destination>  eq 995
access-list 102 extended permit tcp <source>  <destination>  eq 465
access-list 102 extended permit tcp 172.16.20.0  117.102.8.90  eq 995
access-list 102 extended permit tcp 172.16.20.0  117.102.8.90  eq 465
i need to run outlook of lan users having subnet 172.16.20.0/24 and after that is apply
access-group 102 in interface inside ?
Navaz
access-list 102 extended permit tcp 172.16.20.0  255.255.255.0  117.102.8.90  eq 995
access-list 102 extended permit tcp 172.16.20.0  255.255.255.0 117.102.8.90  eq 465
Thanks JoshiI applied this
Thanks Joshi
I applied this but outlook is not working.
i attached outlook setting.
Navaz
I can only see the ports in
I can only see the ports in your configuration ,what is the incoming and outgoing mailserver name/IP configured in your outlook, If its name and not an IP then how the name resolution will happen, do you have an inside DNS server ?
Prashant Joshi
i have Incoming server 174
Thanks Joshi
i have Incoming server 174.142.165.146 Outgoing Server 174.142.165.146.
And these are outside over the internet anywhere but not in our LAN network and there is no DNS server.
Navaz
Hi,kindly provide me below
kindly provide me below output :
 packet-tracer input inside tcp 172.16.20.10 5656 174.142.165.146 995 det
 packet-tracer input inside tcp 172.16.20.10 5656 174.142.165.146 465 det
Prashant Joshi
Please find the attached the
Please find the attached the required file
Navaz
you need to remove below NAT
you need to remove below NAT exempt ( it means for all inside users ASA will not perform a NAT)
nat (inside) 0 0.0.0.0 0.0.0.0
If you need to perform NAT exempt, you need to be specific like
access-list nonat permit 10.10.10.0 255.255.255.0 11.11.11.0 255.255.255.0
nat (inside) 0  access-list nonat
Prashant Joshi
These are the nat commands
These are the nat commands that i configured
nat-control
global (Outside) 1 interface
nat (DMZ) 1 10.1.1.0 255.255.255.0
Navaz
Add below  NAT policy for
Add below  NAT policy for inside users
nat (inside) 1 172.16.20.0  255.255.255.0
and if it doesn't work provide packet tracer output again.
Prashant Joshi
414
