Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Internet Connection for Public Library
I need some help on how to deploy this setup. The fios internet connection was installed in our data center but the public users are located on the other end of our network. Hence, this connection needs to traverse thru our internal network. I would like this internet traffic to not be visible internally. Do I use 2 firewalls? one on the DMARC end and one on the public users end? Please advise. Thanks
Abraham
Re: Internet Connection for Public Library
Hello Abraham
How are the closets/switches between the edge (where the public users are sitting)and datacenter connecting ? If you are running a trunk between these buildings, you can just assign a Layer 2 VLAN called "Guests" and trunk it over to the datacenter and directly terminate it either on the core switch or the firewall. By doing this , layer 3 visibility of the internet traffic can be avoided. you dont need additional firewalls here, but it really depends on your connectivity..
Hope this helps.. all the best.. rate replies if found useful.
Raj
Community Member
Hi Raj, The traffic goes thru several hops from the library to our data center via layer 3 switches. How can I prevent the public users from our internal network? Don't I need 2 firewalls at each end? If I do, how it the public users FW configured?
C:\Documents and Settings\>tracert 192.168.125.1
Tracing route to car-jrl1.xxx.com [192.168.125.1]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms [10.1.1.1]
2 <1 ms <1 ms <1 ms [10.1.1.10]
3 <1 ms <1 ms <1 ms 172.30.124.2
4 <1 ms 1 ms <1 ms [192.168.125.1]
Trace complete.
Abraham
Gold
VRF? Policy based routing? VPN?
Community Member
None of those. I just want to isolated the public internet users from our internal network. The porblem is these users have to traverse thru our internal network to access the fios internet. I have FW setup on the datacenter side where fios terminates. Thanks!
Community Member
Abraham,
If you want to limit a specific vlan from accessing the company's internal resources, why don't you create an access-group on the vlan interface and only grant them access to the Internet. That will work.
397
