Internet connection issues with 5510
I am setting up an ASA 5510 using the ASDM interface.  It's a basic config with outside, inside, and management interfaces.  The problem I'm having is that my PC on the inside interface will not browse or ping anything outside of the interface.  I do have dynamic NAT established and have verified that the address is translating correctly.  In fact, I can run the packet tracer in the ASDM from the inside to an outside address and it is successful.  Here is my config.  Any help would be appreciated.
ASA Version 8.4(4)1
hostname
domain-name
enable password knNonXPFJemAfUMd encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
nameif Outside
security-level 0
ip address **.***.80.210 255.255.255.252
interface Ethernet0/1
nameif Inside
security-level 100
ip address 192.168.1.254 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
nameif management
security-level 100
ip address 192.168.2.1 255.255.255.0
management-only
boot system disk0:/asa844-1-k8.bin
ftp mode passive
dns domain-lookup Outside
dns domain-lookup Inside
dns server-group DefaultDNS
name-server **.***.**.*
name-server ***.***.***.*
domain-name
object network **.***.80.32
range **.***.80.33 **.***.80.61
description Range for NAT
object network Yoda_gigabitethernet
host **.***.80.209
description Gateway for Vader
pager lines 24
logging enable
logging asdm informational
mtu Outside 1500
mtu Inside 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-649-103.bin
no asdm history enable
arp timeout 14400
nat (Inside,Outside) after-auto source dynamic any **.***.80.32
route Outside 0.0.0.0 0.0.0.0 **.***.80.209 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.2.0 255.255.255.0 management
http 192.168.1.0 255.255.255.0 Inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 Inside
ssh 192.168.2.0 255.255.255.0 management
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 192.168.1.20-192.168.1.30 Inside
dhcpd dns **.***.80.1 ***.***.144.1 interface Inside
dhcpd lease 28800 interface Inside
dhcpd domain  interface Inside
dhcpd enable Inside
dhcpd address 192.168.2.2-192.168.2.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:100669a085c1ceaa91f3c0a34abf13a8
: end
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Internet connection issues with 5510
Hello Chase,
I think you do not understand what my co-worker tried to explain.
Please check the following:
nameif Outside
security-level 0
So you can see it's a /30 netmask
Here is the route statement you have
That route is covered on the /30 netmask so we are good on that
Now check the following:
80.32 is not on the scope of the /30 netmask so you cannot use it, even though if you have bought a bigger range you have not applied it yet to the outside interface and since on 8.4.3 you cannot proxy arp ip addresses out of the scope of the outside interface then you will need to assing an IP address on the same range for the NAT to work.
Do the following and let us know man:
no nat (Inside,Outside) after-auto source dynamic any **.***.80.32
no route Outside **.***.80.32 255.255.255.224 64.130.80.209 1
nat (inside,outside) after-auto source dynamic any interface
Just remember to rate the helpful posts, that is also taken as a thank you
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hello Chase,
First of all enable the stateful inspection for the ICMP protocol to make the ICMP work across the firewal
     -Fixup protocol ICMP
Second , from the ASA can you ping  **.***.80.209
if the answer is YES, then from the ASA ping 4.2.2.2
Let me know those 3 resulst
Remember to rate all the helpful posts
Julio
Bronze
Hello Chase,
I can see you are NATing the traffic to **.***.80.32
It doesn't look like that is one of available IP addresses.
Can you change it to .80.210
Felipe
Julio,
First of all, thanks for the help.  I enabled ICMP; however, I still can't ping outside the interface.
Felipe,
I added a static route for the NATed addresses to the outside interface with no luck.  Here is an updated config:
ASA Version 8.4(4)1
hostname
domain-name
names
nameif Outside
security-level 0
nameif Inside
security-level 100
shutdown
no nameif
no security-level
no ip address
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 100
management-only
ftp mode passive
domain-name
host **.***.80.209
pager lines 24
logging enable
mtu Outside 1500
mtu Inside 1500
mtu management 1500
arp timeout 14400
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable Inside
webvpn
parameters
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
inspect icmp
call-home
profile CiscoTAC-1
  no active
: end
Hello Chase,
nameif Outside
security-level 0
Ok,
I changed some things around so that everything should be in the same range:
nameif Outside
security-level 0
ip address **.***.80.33 255.255.255.224
range **.***.80.35 **.***.80.60
route Outside 0.0.0.0 0.0.0.0 **.***.80.62 1
Moving everything into the same subnet fixed my problem!  We are replacing an old PIX where you could use addresses outside of the scope for NATing.  Thanks again for your help!
398
