IOS 8.2.2 Question
Hi all,
I upgraded an ASA5505 with IOS 8.2.2 and copied a config file from another production ASA but then the ASA5505 (8.2.2) won't establish the tunnel with the ISR, I can't telnet or SSH to the ASA. I verified the config file and compare it with the production one and they are the same (different inside and outside IPs, of course). Any ideas why I am having these issues?
Copy of config file attached.
Thanks in advance,
sK
1 REPLY
Re: IOS 8.2.2 Question
Seems like you have multiple issues.
Let us see if you can get you to be able to SSH first.
12.52.61.150 does not respond to icmp or may be the interface is not up.
1. If you do "sh int vlan2" does it show up up?
2. try to generate the key-pair "cry key generate rsa modulus 1024" and then try ssh to the outside ip 12.52.61.150 again.
-KS
299
