Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
IP SLA - Previous Route is not going away after applying Track Keyword
Hi All,
I have configured IP SLA on Cisco ASA running ios 9.1(3).
I have already a default route as follows:
route outside 1
Now I have applied IP sla.
route outside 1 track 100
Now I could see both statements in the running config.
route outside 1 track 100   <<<<<<<< SLA applied
route outside 1             <<<<< previous default route  still exists in the routing table.
route outside2 254      <<<<< backup IPS route.
Could you please confirm following:
1. Is it a default behaviour of seeing both route statements.
2. Do we need to delete previous default route in the running config.
3. Is this a bug?
Thank You,
Everyone's tags (2)
Community Member
Did you configured track 100?
Did you configured track 100? Could you give its config?
Community Member
Here is the config: sla
Here is the config:
sla monitor 10
type echo protocol ipIcmpEcho interface outside
num-packets 3
frequency 10
sla monitor schedule 10 life forever start-time now
track 100 rtr 10 reachability
Community Member
Thanks, why you just dont
Thanks, why you just dont delete old statement?
Community Member
I can delete the old
I can delete the old statement. But in router, the same command is overwriting. Need to test this in the older ASA version. Currently ASAs are in 9.1
