Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
IPSEC connection using Multiple Context
I read that when you enable multiple contexts that it disables VPN services such as IPSEC is this true? I have a client that has two ASA across a WAN and they want to secure the traffic and extend over to either side the different VLANs.
Re: IPSEC connection using Multiple Context
Yes its true.
Multiple context mode does not support the following features:
Dynamic routing protocols
Security contexts support only static routes. You cannot enable OSPF or RIP in multiple context mode.
•VPN
•Multicast
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/contexts.html#wp1116132
Narayan
sounds good..so what would you suggest if the following.
vlan1,2,3,4--(ASA)----WANCLOUD----(ASA)--Vl1,2,3,4
I am trying to extend the different vlans across
in a secure fashion. could i just simply trunk
the two on either side and use an IPSEC tunnel in the middle? But then i will not be able to keep the traffic separate for each vlan? any suggestions?
134
