IPSEC on external Interface of ASA5505
Hi, we have two internal 5505 firewalls protecting our emergency services subnets from the rest of the organisation. The setup is quite simple, allow all traffic to pass between the two protected sites but nothing else. The Interface facing the organisation and hence my PC which is used for configuring is the External interface. The problem I have is getting Telnet and SSH access to the device through the external interface. I understand i need to setup IPSEC on this but basically I dont know how to. Can some kind soul point me in the right direction? Either a relevant document or some simple steps for a dummy?
Thanks, Ray
Re: IPSEC on external Interface of ASA5505
Ray,
Below are some config examples, all you need is on this link:-
http://www.cisco.com/en/US/products/ps6120/prod_configuration_examples_list.html
HTH>
Gold
you can ssh to the external interface w/o having to go over ipsec, not the case w/ telnet.
130
