ipsec UDP reverse path check
ASA running 8.2(5).
When vpn clients connect with a ipsec vpn client configured as a zero tunnel route (0.0.0.0/0) the ASA logs the below:
Deny UDP reverse path check from 192.168.200.47 to 192.168.11.200 on interface HOSTING
192.168.200.0/24 is the subnet where the ipsec clients gets a ip address from when connecting.
192.168.11.200 in this case the the clients own local subnet. Is it expected that the ASA box will log these messages from clients local subnet when they are connected with ipsec vpn and it is a zero tunnel configuration?
Interfaces and routes:
Current available interface(s):
  DATA-BACKUP     Name of interface Redundant1.10
  DMZ             Name of interface Redundant1.900
  GUEST           Name of interface Redundant1.990
  HOSTING         Name of interface Redundant1.100
  Infrastruktur   Name of interface Redundant1.20
  Intern          Name of interface Management0/0
  OUTSIDE-BACKUP  Name of interface Redundant1.998
  PHONE           Name of interface Redundant1.200
  SPECTRA-LAN     Name of interface Redundant1.50
  outside         Name of interface Ethernet0/3
Gateway of last resort is 1.2.3.4 to network 0.0.0.0
C    172.31.0.0 255.255.255.0 is directly connected, DMZ
S    192.168.200.46 255.255.255.255 [1/0] via 1.2.3.4, outside
S    192.168.200.47 255.255.255.255 [1/0] via 1.2.3.4, outside
S    VPN-hosting 255.255.255.0 [1/0] via 192.168.200.1, outside
C    93.167.197.80 255.255.255.240 is directly connected, outside
S    10.100.110.0 255.255.255.0 [1/0] via 10.100.110.1, outside
C    10.10.10.0 255.255.255.0 is directly connected, GUEST
C    10.100.100.0 255.255.255.0 is directly connected, Intern
S    10.100.101.0 255.255.255.0 [5/0] via 10.100.100.252, Intern
S    10.100.0.0 255.255.0.0 [10/0] via 10.100.100.252, Intern
C    10.200.100.0 255.255.252.0 is directly connected, PHONE
C    10.199.1.0 255.255.255.0 is directly connected, Infrastruktur
C    10.199.0.0 255.255.255.0 is directly connected, DATA-BACKUP
C    192.168.254.0 255.255.255.0 is directly connected, HOSTING
S*   0.0.0.0 0.0.0.0 [1/0] via 1.2.3.4, outside
S    192.168.0.0 255.255.0.0 [5/0] via 192.168.254.1, HOSTING
Robert
Everyone's tags (5)
1 ACCEPTED SOLUTION
Super Bronze
Yes, because you don't configure split tunnel, all traffic including local vpn client subnet will also be routed through the VPN tunnel. If your vpn client needs to access their own local LAN while connected to the VPN tunnel, then you would need to configure split tunnel.
Super Bronze
Thanks.
Robert
1137
