Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Is it possible for LAN users to go online without configuring a access List
I am using pix firewall.firewall is connected outside interface is connected to ISP;Inside interface is connected to a switch and users are connected to the switch.
Without configuring a access list to allow incoming traffic,is it possible for users to go online.
Please help.
Arulkumar
Hall of Fame Super Blue
Re: Is it possible for LAN users to go online without configurin
arulkumar80 wrote:
Please help.
Arulkumar
Arulkumar
Yes it is because the pix is a stateful firewall and it allows traffic from the inside to the outside without an access-list so the return traffic will be allowed back in.
What you will need to configure though is some form of NAT/PAT. Usually for internet access -
nat (inside) 1 0.0.0.0 0.0.0.0
global (outside) 1 interface
Jon
As long As Global (outside) & nat (inside) are configured , (the inside and outside keywords refer to the interface"s  names) , you dont need any access-list , as from Higher Security level to lower Security level , traffic are allowed to pass.
from Lower Security level Access to Higher Security level, An Access-list or Conduit must be used to permit the traffic.
Mohamed
176
