Is it possible to setup port triggering on 881
Guys/Gals,
I have an xbox 360 and an xbox one both on my home network but they are never on at the same time, I know I can get a 1 to 1 nat but this will leave one of the devices with a strict nat. I currently have both Xboxes with moderate nat which is ok but I would like to get them both to an open nat state as I did when using my Buffalo router. On this router I had port triggering setup so this didn’t map to a static IP but would open and close natted ports as requested, is there a way of getting port triggering working on a Cisco 881? Currently I have CBAC outbound, an ACL inbound, no static nat translations and nat translation timeouts set. This works fine with everything else on my network.
interface Dialer1
ip access-group XBOXIN in
ip inspect XBOXCBAC out
ip inspect name XBOXCBAC udp timeout 30
ip inspect name XBOXCBAC tcp timeout 30
ip inspect name XBOXCBAC ftp
ip inspect name XBOXCBAC http timeout 30
ip inspect name XBOXCBAC https timeout 30
ip inspect name XBOXCBAC dns timeout 30
ip inspect name XBOXCBAC bittorrent
ip inspect name XBOXCBAC icmp
ip inspect name XBOXCBAC rcmd
ip inspect name XBOXCBAC realaudio
ip inspect name XBOXCBAC tftp
ip inspect name XBOXCBAC h323
ip access-list extended XBOXIN
 permit tcp any any eq telnet
 deny   ip any any log
ip nat translation port-timeout tcp 3074 30
ip nat translation port-timeout udp 3074 30
ip nat translation port-timeout udp 53 30
ip nat translation port-timeout tcp 53 30
ip nat translation port-timeout tcp 80 30
ip nat translation port-timeout udp 88 30
ip nat translation port-timeout udp 500 30
ip nat translation port-timeout udp 3544 30
ip nat translation port-timeout udp 4500 30
Any suggestions would be gratefully accepted and thanks in advance.
Cheers Dean
  • Firewalling
119
