Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
isakmp policy initiator does not negotiate PIX515e 7.2(1)
PIX515 has the following isakmp policy.
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 20
authentication pre-share
encryption 3des
hash md5
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 40
encryption des
hash md5
group 2
lifetime 86400
crypto isakmp policy 50
encryption des
hash sha
group 2
lifetime 86400
crypto isakmp policy 60
encryption des
hash sha
group 1
lifetime 86400
Outside IPSec VPN peers will not connect if the isakmp policy is set to 3DES-SHA. D-LINK, Linksys, SonicWall WatchGuard, etc must have the phase 1 set to 3DES-MD5 which is my highest priority shown above.
Any clue why negotiation isn't happening?
Bronze
Re: isakmp policy initiator does not negotiate PIX515e 7.2(1)
hello,
you can turn on debug and check what's happening.
debug crypto ipsec
debug crypto isakmp
HTH, PRI
Here's a cut of the error messages.
Feb 07 11:22:31 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:22:35 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:22:41 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:22:50 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:22:51 172.16.xx.xx local4.err %PIX-3-713902: Group = 68.85.xxx.xxx, IP = 68.85.xxx.xxx, QM FSM error (P2 struct &0x29f80b0, mess id 0xc0abab34)!
Feb 07 11:22:51 172.16.xx.xx local4.debug %PIX-7-715065: Group = 68.85.xxx.xxx, IP = 68.85.xxx.xxx, IKE QM Initiator FSM error history (struct &0x29f80b0) , : QM_DONE, EV_ERROR-->QM_WAIT_MSG2, EV_TIMEOUT-->QM_WAIT_MSG2, NullEvent-->QM_SND_MSG1, EV_SND_MSG-->QM_SND_MSG1, EV_START_TMR-->QM_SND_MSG1, EV_RESEND_MSG-->QM_WAIT_MSG2, EV_TIMEOUT-->QM_WAIT_MSG2, NullEvent
Feb 07 11:22:51 172.16.xx.xx local4.debug %PIX-7-713906: Group = 68.85.xxx.xxx, IP = 68.85.xxx.xxx, sending delete/delete with reason message
Feb 07 11:22:52 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:22:53 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:22:59 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:23:04 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:23:11 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:23:12 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:23:20 172.16.xx.xx local4.notice %PIX-5-713904: IP = 68.85.xxx.xxx, Received encrypted packet with no matching SA, dropping
Feb 07 11:23:23 172.16.xx.xx local4.err %PIX-3-713902: Group = 68.85.xxx.xxx, IP = 68.85.xxx.xxx, QM FSM error (P2 struct &0x31eb6a8, mess id 0xca21d6f7)!
Bronze
hello,
have you got pfs = yes in your config.
anyways, this error which you are getting could be due to if one of the side have configured IKEv2 instead of IKEv1.
HTH, PRI
HI .. this sort of errors are generally related to mismatches between the peers .. I suggest making sure that Phase 1 and 2 parameters are the same in the PIX and the other peer.
I hope it helps .. please rate it if it does!!!
513
