Issue with ASDM - PIX 535
Hi, I have the following situation:
When I try to save changes done through ASDM I'm getting the following Error Message:
However, if I save the running-config through the CLI I have no problems, and the performance of the device seem to be ok, I mean, the only problem I have is when I try to save changes through the ASDM, the configuration is loaded without problem.
Can any body help me??
Thanks!!
  • Firewalling
Everyone's tags (4)
Hello Christian,
How, weird behavior.
Are you running any ASDM Role??
What is the ASDM Version you have  and Pix version?
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hi Julio.
Thanks for responding.
This is a part of show version from the PIX :
fwcol# sho ver
Cisco PIX Security Appliance Software Version 8.0(4)
Device Manager Version 6.1(5)
Compiled on Thu 07-Aug-08 19:42 by builders
System image file is "flash:/pix804.bin"
Config file at boot was "startup-config"
Hardware:   PIX-535, 1024 MB RAM, CPU Pentium III 1000 MHz
Sorry, I am not expert in ASDM, so how can I verify if am I running an ASDM role? could you explain your question again?
BR,
Hello Christian,
You are running the Cisco recommended version so wre are done there.
PIX 8.0(4)
ASDM 6.1(3)1 and later. Recommended: 6.1(5).
I mean if you enable any kind of authorization configuration on the Firewall?
Can you share the configuration,
Cheers,
Julio, thank you.
The authorization configurations on the firewall are given by the privilege levels configured for the local users.
What especific part of the configuration you want to share?
show run aaa
show run username for the user having the issue (just show us the privilege level)
show run privilege
Cheers,
fw# sho run aaa
aaa authentication telnet console LOCAL
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
aaa accounting enable console TACACS+
aaa accounting ssh console TACACS+
aaa accounting telnet console TACACS+
aaa accounting command TACACS+
fw# sho run username cxxxxx
username cxxxxx password XXXXXX encrypted privilege 15
fw# sho run privileg
privilege cmd level 1 mode exec command logout
privilege cmd level 1 mode exec command disable
privilege cmd level 3 mode exec command perfmon
privilege cmd level 8 mode exec command copy
privilege cmd level 3 mode exec command more
privilege cmd level 3 mode exec command ping
privilege cmd level 3 mode exec command who
privilege cmd level 3 mode exec command logging
privilege cmd level 3 mode exec command failover
privilege cmd level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command running-config
privilege show level 3 mode exec command reload
privilege show level 3 mode exec command mode
privilege show level 3 mode exec command firewall
privilege show level 3 mode exec command interface
privilege show level 3 mode exec command clock
privilege show level 3 mode exec command dns-hosts
privilege show level 3 mode exec command access-list
privilege show level 3 mode exec command logging
privilege show level 3 mode exec command ip
privilege show level 3 mode exec command failover
privilege show level 3 mode exec command asdm
privilege show level 3 mode exec command arp
privilege show level 3 mode exec command route
privilege show level 3 mode exec command ospf
privilege show level 3 mode exec command aaa-server
privilege show level 3 mode exec command crypto
privilege show level 3 mode exec command vpn-sessiondb
privilege show level 3 mode exec command ssh
privilege show level 3 mode exec command dhcpd
privilege show level 3 mode exec command blocks
privilege show level 3 mode exec command uauth
privilege show level 3 mode configure command interface
privilege show level 3 mode configure command clock
privilege show level 3 mode configure command access-list
privilege show level 3 mode configure command logging
privilege show level 3 mode configure command ip
privilege show level 3 mode configure command failover
privilege show level 5 mode configure command asdm
privilege show level 3 mode configure command arp
privilege show level 7 mode configure command static
privilege show level 3 mode configure command route
privilege show level 3 mode configure command aaa-server
privilege show level 3 mode configure command crypto
privilege show level 3 mode configure command ssh
privilege show level 3 mode configure command dhcpd
privilege show level 5 mode configure command privilege
privilege clear level 3 mode exec command dns-hosts
privilege clear level 3 mode exec command logging
privilege clear level 3 mode exec command arp
privilege clear level 3 mode exec command aaa-server
privilege clear level 3 mode exec command crypto
Add
aaa authentication http console LOCAL
Cheers,
401
