Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
tb
Issue with famous "no translation group found" error
Hello, I'm getting the famous "No translation group found for tcp src" error and can't see the reason.
My config is a little strange. The outside interface is not used (reserved for future integration), the inside interface points to the user network 172.31.48.0/22 and the IF_SECURE_MGMT interface connects to 192.168.102.0/23 network.
What I want to achieve is NATting the traffic to all destinations coming from the IF_SECURE_MGMT interface except for destinations in the user network 172.31.48.0/22.
When trying to access a server in 192.168.102.0/23 network eg by RDP from a host in the user network 172.31.48.0/22 the "no translation group found" error pops up.
This is a part of the ASA 5510 config, it's still running version 8.2:
interface Ethernet0/0
shutdown
nameif outside
security-level 0
no ip address
ospf cost 10
interface Ethernet0/1
speed 1000
duplex full
nameif inside
security-level 100
ip address 172.31.48.4 255.255.252.0
ospf cost 10
interface Ethernet0/1.102
vlan 102
nameif IF_SECURE_MGMT
security-level 90
ip address 192.168.103.254 255.255.254.0
ospf cost 10
access-list ACL_INSIDE_ACCESS_IN extended permit tcp object-group OG_NETWORK_MANAGEMENT_HOSTS LOCAL_LAN_MANAGEMENT 255.255.254.0 object-group OG_SERVICE_NETWORK_MANAGEMENT_TCP
access-list ACL_INSIDE_ACCESS_IN extended permit udp object-group OG_NETWORK_MANAGEMENT_HOSTS LOCAL_LAN_MANAGEMENT 255.255.254.0 object-group OG_SERVICE_NETWORK_MANAGEMENT_UDP
access-list ACL_NONAT_IF_SECURE_MGMT extended permit ip LOCAL_LAN_MANAGEMENT 255.255.254.0 LOCAL_LAN_DGB_BVV 255.255.252.0
nat (IF_SECURE_MGMT) 0 access-list ACL_NONAT_IF_SECURE_MGMT
nat (IF_SECURE_MGMT) 11 LOCAL_LAN_MANAGEMENT 255.255.254.0 outside
global (inside) 11 interface
Any help appreciated. Thanks.
Everyone's tags (1)
1 REPLY
Hi Thomas,
Rememeber that the Nat 0 must be placed in the higher security level interface.
Luis Silva
"If you need PDI (Planning, Design, Implement) assistance feel free to reach us"
http://www.cisco.com/web/partners/tools/pdihd.html
Luis Silva "If you need PDI (Planning, Design, Implement) assistance feel free to reach us" http://www.cisco.com/web/partners/tools/pdihd.html
136
