Issue with LAN Failover
Does this output of the show failover seem correct?.. Why are there 0.0.0.0 address for the subinterfaces
this is the Active FW--we are running in multiple context...with all the "work" being done in this context
XFW/core# show failover
Failover On
Last Failover at: 11:49:03 UTC Apr 5 2009
        This context: Active
                Active time: 44258322 (sec)
                  Interface Core_Handoff (10.11.24.10): Normal (Waiting)
                  Interface DMZ_Handoff (10.11.20.11): Normal (Waiting)
                  Interface CutThruDMZ (172.20.213.10): Normal (Not-Monitored)
                  Interface VIPs (172.20.224.1): Link Down (Not-Monitored)
                  Interface Direct (172.20.250.1): Normal (Not-Monitored)
        Peer context: Standby Ready
                Active time: 0 (sec)
                  Interface Core_Handoff (0.0.0.0): Normal (Waiting)
                  Interface DMZ_Handoff (0.0.0.0): Normal (Waiting)
                  Interface CutThruDMZ (0.0.0.0): Normal (Not-Monitored)
                  Interface VIPs (0.0.0.0): Normal (Not-Monitored)
                  Interface Direct (0.0.0.0): Normal (Not-Monitored)
Secondary
XFW1/core# sh failover
Failover On
Last Failover at: 11:51:17 UTC Apr 5 200
        This context: Standby Ready
Last Failover at: 11:51:17 UTC Apr 5 2009
                  Interface VIPs (0.0.0.0): Link Down (Not-Monitored)
        Peer context: Active
                Active time: 44258266 (sec)
                  Interface VIPs (172.20.224.1): Normal (Not-Monitored)
Re: Issue with LAN Failover
Have you defined secondary addresses for the interfaces? If no, then what
you see is normal.
http://www.cisco.com/en/US/products/ps6120/products_configuration_example091
86a0080834058.shtml#prim
Hope this helps.
NT
NT is correct.
Youre missing Standby IP addresses in firewall configuration. Once you configure a standby IP for each interface, the 0.0.0.0 will be configured with the configured standby IP address.
207
