Issue with NAT
I am trying to meet the following requirements:-
I need to be able to get traffic from the inside interface to route out through the 172.16.15.0 network to a further secure router. Obviously I need to allow flow back from the router in the 172.16.15.0 network into the inside interface.
Currently I am unable to ping any device including the 172.16.15.1 interface of the network in the pix.
I do not want any NAT to take place between any of the interfaces.
My outside interface does however seem to accept traffic from the legacy1 network fine.
Any suggestions or examples would be very appreciated as I am going round and round in circles with this one!
Simon
Building configuration...
: Saved
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
interface ethernet3 auto shutdown
interface ethernet4 auto
interface ethernet5 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 legacy1 security1
nameif ethernet3 imaging security95
nameif ethernet4 Encryption security1
nameif ethernet5 intf5 security10
enable password xxx
passwd xxx
hostname pixfirewall
domain-name ciscopix.com
names
access-list inside_access_in permit ip any any
access-list Encryption_inbound_nat0_acl permit ip any any
access-list legacy1_outbound_nat0_acl permit ip any any
access-list outside_inbound_nat0_acl permit ip any any
access-list outside_access_in permit ip any any
access-list imaging_access_in permit ip any any
access-list inside_outbound_nat0_acl permit ip any any
access-list Encryption_access_in permit ip any any
pager lines 24
logging on
icmp permit any inside
icmp permit any legacy1
icmp permit any imaging
icmp permit any Encryption
mtu outside 1500
mtu inside 1500
mtu legacy1 1500
mtu imaging 1500
mtu Encryption 1500
mtu intf5 1500
ip address outside 10.155.64.5 255.255.255.0
ip address inside 192.168.118.198 255.255.255.224
ip address legacy1 195.210.x.x.255.0
ip address imaging 10.195.199.5 255.255.255.0
ip address Encryption 172.16.15.1 255.255.255.0
no ip address intf5
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address legacy1
no failover ip address imaging
no failover ip address Encryption
no failover ip address intf5
pdm location 0.0.0.0 0.0.0.0 inside
pdm location 192.168.1.0 255.255.255.0 inside
pdm location 0.0.0.x.x.255.0 outside
pdm location 192.168.0.0 255.255.0.0 inside
pdm location 20.x.x.176 255.255.255.240 Encryption
pdm location 20.x.x.0 255.255.255.0 Encryption
pdm location 20.x.x.0 255.255.255.0 imaging
pdm location 192.168.118.198 255.255.255.255 Encryption
pdm location 192.168.118.198 255.255.255.255 imaging
pdm location 172.16.15.0 255.255.255.0 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 20 interface
global (inside) 20 interface
global (imaging) 20 interface
nat (outside) 0 access-list outside_inbound_nat0_acl outside
nat (inside) 0 access-list inside_outbound_nat0_acl
nat (inside) 0 192.168.0.0 255.255.0.0 0 0
nat (inside) 20 0.0.0.0 0.0.0.0 0 0
nat (legacy1) 0 access-list legacy1_outbound_nat0_acl
nat (legacy1) 0 0.0.0.0 0.0.0.0 0 0
nat (Encryption) 0 access-list Encryption_inbound_nat0_acl outside
access-group outside_access_in in interface outside
access-group inside_access_in in interface inside
access-group imaging_access_in in interface imaging
access-group Encryption_access_in in interface Encryption
route outside 0.0.0.0 0.0.0.0 10.155.64.1 1
route inside 192.168.0.0 255.255.0.0 192.168.118.198 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0
Bronze
Re: Issue with NAT
Unfortunately pix 6.3 doesn't have any good way to turn off nat entirely without entering a couple of commands: there are a couple of ways to do this, but I would do the following
1) Get rid of all your nat and global statements
2) Enter the following commands:
access-list al_no_nat permit ip any any
nat (inside) 0 access-list al_no_nat
nat (legacy1) 0 access-list al_no_nat
nat (imaging) 0 access-list al_no_nat
nat (outside) 0 access-list al_no_nat
Though technically you don't really need the last one, as the nat requirements are from high to low and theres nothing lower than 0
3) do a 'clear xlate' to wipe out any existing xlates that may have been created
4) Test
Now this is where you need to understand a little bit about security on the pix - the pix will not allow you to tranverse the pix to ping another interface: meaning you can't ping the outside interface from and inside ip address (and vice-versa). What you need to do is have an IP out on the Encryption interface that you can ping (possibly a router) and on that device have it route the 192.168 network back to the 172.16.15.1 interface on your firewall. Then an inside host should ping that and be able to get a reply right (assuming the routing is in place to get that network back to the firewall)
Your permit ip any any ACLs should allow all the traffic return that needs to for connectivity to work.
Other than that, the config looks good, though nothing is being routed to the Encryption interface as of yet (your outside network has the default route).
--Jason
Please rate this message if it helped solve some or all of your issue.
Re: Issue with NAT
Jason.
Thank you so very much. Excellent answer. The only change I made due to others utilising the pdm was to create individual access lists for the interfaces as the pdm does not allow you to utilise it more than once.
All up and working.
Thanks again.
Simon
199
