Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Issue with SMTP & SCP services on ASA5510
Iam using an ASA5510 firewall in one of our plants. I'm using one WAN (Link 0) & two LANs (Link 1& Link 2).
WAN: 10.127.225.8
LAN 1: 172.16.0.xxx
LAN 2: 192.168.75.xxx
Protocol communications between LAN1 & WAN: SCP, OMPRO (Customised TCP/IP ports), Ping (ICMP)
Protocol communications between LAN2 & WAN: SMTP, RDP, Database Equalisation, Ping (ICMP)
We've created necessary NATs, Access rules etc and most of (in fact all) two way protocols are through. ie, the protocols where it is a query-response, it works across the firewall. However, we are stuck with the one side communications like SCP data dump & SMTP mailing service. Also, the ping isn't going through from inside to outside.
This is the first time I'm working with an ASA5510. I've used my knowledge of configuring ASA5505 here but no luck. Could anyone help? I'm giving the configuration below (same is attached alongwith):
: Saved
ASA Version 8.4(4)1
hostname LDPEASA5510
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
 nameif RILIT
 security-level 0
 ip address 10.127.225.8 255.255.255.0
interface Ethernet0/1
 nameif LDPE
 security-level 100
 ip address 172.16.0.10 255.255.255.0
interface Ethernet0/2
 nameif DMZ
 security-level 100
 ip address 192.168.75.10 255.255.255.0
interface Ethernet0/3
 shutdown
 no nameif
 no security-level
 no ip address
interface Management0/0
 nameif management
 security-level 100
 ip address 192.168.1.10 255.255.255.0
 management-only
ftp mode passive
clock timezone IST 5 30
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network AIMS
 host 192.168.75.100
 description AIMS CLIENT
object network CIMIO
 host 172.16.0.21
 description CIMIO SERVER
object network ENTSRV
 host 10.127.233.9
 description ALARM ENTERPRISE SERVER
object network IP21
 host 10.127.226.21
 description IP21 SERVER
object network OPCSRV
 host 172.16.0.1
 description OPC SERVER
object network NTP1
 host 10.127.229.26
 description NTP SERVER 1
object network NTP2
 host 10.127.226.49
 description NTP SERVER 2
object network OMPRO
 host 10.127.226.106
 description OMPRO SERVER
object network SMTPSRV
 host 10.22.140.3
 description SMTP SERVER
object network TESTCLIENT
 host 10.127.230.35
 description TEST CLIENT PC
object network AIMS1
 host 192.168.75.100
 description AIMS HTTP
object network AIMS2
 host 192.168.75.100
 description AIMS HTTPS
object network CIMIO1
 host 172.16.0.21
 description CIMIO10041
object network CIMIO2
 host 172.16.0.21
 description CIMIO47625
object network CIMIO3
 host 172.16.0.21
 description CIMIO7777
object network CIMIO4
 host 172.16.0.21
 description CIMIO10043
object network CIMIO5
 host 172.16.0.21
 description CIMIO10044
object network CIMIO6
 host 172.16.0.21
 description CIMIO10045
object network CIMIO7
 host 172.16.0.21
 description CIMIO5093
object network CIMIO8
 host 172.16.0.21
 description udp5093
object network AIMS3
 host 192.168.75.100
 description RDP
object network AIMS4
 host 192.168.75.100
object network AIMS5
 host 192.168.75.100
object-group network NTPSRV
 description NTPSRV
 network-object object NTP1
 network-object object NTP2
object-group service CIMIOD tcp
 description CIMIOD
 port-object eq 10042
 port-object eq 7777
 port-object eq 10041
 port-object eq 47625
object-group service CIMIOL tcp-udp
 description CIMIOL
 port-object eq 5093
object-group service RDP tcp-udp
 description RDP
 port-object eq 3389
object-group service SCP tcp
 description SCP
 port-object eq ssh
object-group service SQLE tcp
 description EQUALISE
 port-object eq 1433
object-group service SQLI tcp-udp
 description SQLI
 port-object eq 135
object-group service CIMIOSF tcp
 description CIMIOSF
 port-object eq 10043
 port-object eq 10044
 port-object eq 10045
object-group service DM_INLINE_TCP_1 tcp
 group-object CIMIOD
 group-object CIMIOL
 group-object CIMIOSF
object-group service DM_INLINE_SERVICE_1
 service-object tcp-udp destination eq www
 service-object tcp destination eq https
object-group service DM_INLINE_TCP_3 tcp
 group-object RDP
 group-object SQLE
 group-object SQLI
object-group service DM_INLINE_TCP_4 tcp
 port-object eq www
 port-object eq https
object-group service DM_INLINE_TCP_5 tcp
 group-object CIMIOD
 group-object CIMIOL
object-group service OPCA tcp
 description OPCA
 port-object range 1024 65535
object-group service OPCD tcp
 description OPCD
 port-object range 39000 39500
object-group service DM_INLINE_TCP_2 tcp
 group-object SQLE
 group-object SQLI
 group-object RDP
access-list RILIT_access_in extended permit icmp any any
access-list RILIT_access_in extended permit tcp object ENTSRV object AIMS object-group DM_INLINE_TCP_3
access-list RILIT_access_in extended permit tcp any object AIMS object-group DM_INLINE_TCP_4
access-list RILIT_access_in extended permit tcp object IP21 object CIMIO object-group DM_INLINE_TCP_5
access-list RILIT_access_in extended permit tcp object TESTCLIENT object CIMIO object-group CIMIOD
access-list LDPE_access_in extended permit icmp any any
access-list LDPE_access_in extended permit tcp object CIMIO object OMPRO object-group SCP
access-list LDPE_access_in extended permit tcp object CIMIO object IP21 object-group DM_INLINE_TCP_1
access-list LDPE_access_in extended permit tcp object CIMIO object TESTCLIENT object-group CIMIOD
access-list LDPE_access_in extended permit udp object CIMIO object-group NTPSRV eq ntp
access-list LDPE_access_in extended permit udp object OPCSRV object-group NTPSRV eq ntp
access-list DMZ_access_in extended permit icmp any any
access-list DMZ_access_in extended permit tcp object AIMS object ENTSRV eq 445
access-list DMZ_access_in extended permit tcp object AIMS object SMTPSRV eq smtp
access-list DMZ_access_in extended permit tcp object AIMS object ENTSRV object-group DM_INLINE_TCP_2
access-list DMZ_access_in extended permit udp object AIMS object-group NTPSRV eq ntp
access-list DMZ_access_in extended permit object-group DM_INLINE_SERVICE_1 object AIMS any
pager lines 24
logging enable
logging asdm informational
logging mail informational
logging from-address ldpevmd@ril.com
logging class auth mail emergencies
mtu RILIT 1500
mtu LDPE 1500
mtu DMZ 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
object network AIMS
 nat (any,RILIT) static interface service tcp 1433 1433
 nat (any,RILIT) static interface service tcp 10042 10042
 nat (any,RILIT) static interface service tcp www www
 nat (any,RILIT) static interface service tcp https https
 nat (any,RILIT) static interface service tcp 10041 10041
 nat (any,RILIT) static interface service tcp 47625 47625
 nat (any,RILIT) static interface service tcp 7777 7777
 nat (any,RILIT) static interface service tcp 10043 10043
 nat (any,RILIT) static interface service tcp 10044 10044
 nat (any,RILIT) static interface service tcp 10045 10045
 nat (any,RILIT) static interface service tcp 5093 5093
 nat (any,RILIT) static interface service udp 5093 5093
 nat (any,RILIT) static interface service tcp 3389 3389
 nat (any,RILIT) static interface service tcp 135 135
 nat (any,RILIT) static interface service udp 135 135
access-group RILIT_access_in in interface RILIT
access-group LDPE_access_in in interface LDPE
access-group DMZ_access_in in interface DMZ
route RILIT 0.0.0.0 0.0.0.0 10.127.229.1 1
route RILIT 0.0.0.0 0.0.0.0 10.127.225.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ca trustpoint _SmartCallHome_ServerCA
 crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
 certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
    308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
    0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
    30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
    13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
    0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
    20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
    65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
    65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
    30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
    30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
    496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
    74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
    68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
    3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
    63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
    0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
    a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
    9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
    7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
    15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
    63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
    18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
    4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
    81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
    db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
    7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
    ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
    45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
    2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
    1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
    03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
    69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
    02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
    6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
    c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
    69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
    1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
    551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
    1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
    2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
    4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
    b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
    6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
    481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
    b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
    5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
    6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
    6c2527b9 deb78458 c61f381e a4c4cb66
  quit
telnet timeout 5
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 192.168.1.11-192.168.1.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
ntp server 10.127.226.49 source RILIT prefer
ntp server 10.127.229.26 source RILIT prefer
webvpn
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect http
  inspect icmp
service-policy global_policy global
smtp-server 10.22.140.3
prompt hostname context
call-home reporting anonymous
Cryptochecksum:5f54f87737a77fd452dde6285c95cd06
: end
Hi Krishna, Could you please
Hi Krishna,
Could you please elaborate the concern areas? where to where you have the issue.... if any network diagram related to this if you have... can you share that as well??
It depends on the scenarios...
I see you have done the port based address translation and there are few generic traffic like icmp/smtp is not considered.... so if you give the design and explanation on the issue i will try to assist you with that...
Karthikeyan
Hi Karthikeyan,I've attached
Hi Karthikeyan,
I've attached the network architecture (pdf) & access rules (xls) alongwith.
We had outsourced this job to someone and I must say that I've never seen such a lengthy configuration till date. I seriously doubt whether something have gone horribly wrong.
I hope the documents attached with convey my requirements. If not, feel free to ask. Hope you could guide me.
Thanks and regards,
Krishna
95
