Issues accessing ASDM on ASA platform
Last night I upgraded our ASA 5510 platforms from 7.0 code to 7.2 code.
I also shipped the new ASDM image to Flash (5.2.3).
this morning I wanted to access the ASDM launcher,so I navigated to https://<address of ASA>. I attemtps to authenticate me to the box, but then I get "Page cannot be displayed".
I can perform a sho disk0 and see both the old ASDM image and the new ASDM image and was curious if this might be causing the problem.
Do I need to delete the old ASDM image?
thanks
Re: Issues accessing ASDM on ASA platform
can you post the output of the following command?
show run http
and also:
sh asdm image
sh flash
sh ver
bhiasaip# sho asdm image
Device Manager image file, disk0:/asdm506.bin
bhiasaip# sh flash
-#- --length-- -----date/time------ path
6 5474304 Dec 31 2002 19:04:50 asa706-k8.bin
7 5823980 Jul 21 2007 03:11:10 asdm506.bin
10 8386560 Mar 26 2008 18:59:00 asa723-k8.bin
11 0 Mar 26 2008 17:30:20 crypto_archive
12 6287244 Mar 27 2008 01:54:48 asdm-523.bin
229367808 bytes available (26058752 bytes used)
bhiasaip# sho ver
Cisco Adaptive Security Appliance Software Version 7.2(3)
Detected an old ASDM version.
You will need to upgrade it before using ASDM.
Compiled on Wed 15-Aug-07 16:08 by builders
System image file is "disk0:/asa723-k8.bin"
Config file at boot was "startup-config"
bhiasaip up 1 day 7 hours
Hardware: ASA5510, 256 MB RAM, CPU Pentium 4 Celeron 1600 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CNlite-MC-Boot-Cisco-1.2
SSL/IKE microcode: CNlite-MC-IPSEC-Admin-3.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: Ethernet0/0 : address is 001b.54ab.18f6, irq 9
1: Ext: Ethernet0/1 : address is 001b.54ab.18f7, irq 9
2: Ext: Ethernet0/2 : address is 001b.54ab.18f8, irq 9
3: Ext: Ethernet0/3 : address is 001b.54ab.18f9, irq 9
4: Ext: Management0/0 : address is 001b.54ab.18fa, irq 11
5: Int: Not used : irq 11
6: Int: Not used : irq 5
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 50
Inside Hosts : Unlimited
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 0
GTP/GPRS : Disabled
VPN Peers : 250
WebVPN Peers : 2
This platform has a Base license.
Serial Number: JMX1129L12S
Running Activation Key: xxx
Configuration register is 0x1
Configuration has not been modified since last system restart.
bhiasaip#
Well those commands answered alot indeed. I noticed at the end of the sho ver that it indicated that "the platform has a bad license". Why would it indicate that?
http server enable
http 192.168.1.0 255.255.255.0 management
http 192.168.5.189 255.255.255.255 inside
The 192.168.5.189 inside address is the address of my workstation at the customer site...
have you tried booting asa with the new asdm?
asa(config)asdm image flash:filename.bin
Franco
your asdm can be in flash but if you dont tell the asa to use it, it wont until you instruct it to use it.
that being said, is there any issues with going ahead and using the command you had previously recommended which was:
asdm image flash:asdm-523.bin
and then doing a "wr mem" so that during the next restart, it will reference the correct image?
Thanks again for your assistance.
Have not tried to boot using the new ASDM image. I will have to schedule this to happen at some point, since it guards the customers DMZ and Production networks from the Outside.
Would the command be
asdm image disk0:asdm-523.bin vs. flash??
thanks for your input
203
