Issues SSHing into ASA
I am setting up a new ASA.  Actually it's an old 5510, but this is a new temporary install until the one we ordered comes in.  Everything is working except for SSH.  I have SSH open on the inside and outside interfaces and I get a prompt when I try to SSH to it from either the inside or outside.  But after I put in my username and password it tells me that my credentials are invalid.  I am using a local username/password, not AAA and it accepts that username and password for the console.  Console and telnet (password only) both work so I can get in to make changes.  When I debug SSH, the error states that my username and password are incorrect.  But this happens even when I create a new, simple username/password to test.  I've even gone so far as to copy/paste the username and password into the login window just to be safe (making sure I don't copy spaces, etc).  Below is a copy of the SSH Debug output followed by a sanitized copy of the config.  I have AAA configured for remote VPN users, but not for access to the ASA.  Also, this problem existed before I created the AAA settings for the VPN users.
Also, I have zeroized and regenerated the RSA keys a couple of times to no avail.
SSH Debugs:
Device ssh opened successfully.
SSH0: SSH client: IP = '10.10.1.103'  interface # = 2
SSH: host key initialised
SSH0: starting SSH control process
SSH0: Exchanging versions - SSH-1.99-Cisco-1.25
SSH0: send SSH message: outdata is NULL
server version string:SSH-1.99-Cisco-1.25SSH0: receive SSH message: 83 (83)
SSH0: client version is - SSH-2.0-SecureCRT_4.1.9 (build 278) SecureCRT
client version string:SSH-2.0-SecureCRT_4.1.9 (build 278) SecureCRTSSH0: begin server key generation
SSH0: complete server key generation, elapsed time = 620 ms
SSH2 0: SSH2_MSG_KEXINIT sent
SSH2 0: SSH2_MSG_KEXINIT received
SSH2: kex: client->server aes128-cbc hmac-md5 none
SSH2: kex: server->client aes128-cbc hmac-md5 none
SSH2 0: expecting SSH2_MSG_KEXDH_INIT
SSH2 0: SSH2_MSG_KEXDH_INIT received
SSH2 0: signature length 143
SSH2: kex_derive_keys complete
SSH2 0: newkeys: mode 1
SSH2 0: SSH2_MSG_NEWKEYS sent
SSH2 0: waiting for SSH2_MSG_NEWKEYS
SSH2 0: newkeys: mode 0
SSH2 0: SSH2_MSG_NEWKEYS receivedSSH(MYUSERNAME): user authen method is 'no AAA', aaa server group ID = 0
SSH(ctitech): user authen method is 'no AAA', aaa server group ID = 0
SSH2 0: authentication failed for MYUSERNAME
Sanitized ASA Config:
ASA Version 8.2(2)
hostname ASA
enable password XXXXXXX encrypted
passwd XXXXXXXXX encrypted
names
dns-guard
interface Ethernet0/0
nameif OUTSIDE
security-level 0
ip address x.x.x.x 255.255.255.128
interface Ethernet0/1
nameif INSIDE
security-level 100
ip address 10.10.1.2 255.255.255.0
interface Ethernet0/2
shutdown
no nameif
no security-level
no ip address
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
shutdown
no nameif
no security-level
no ip address
boot system disk0:/asa822-k8.bin
ftp mode passive
access-list outside_access_in extended permit tcp any host X.X.X.X eq smtp
access-list outside_access_in extended permit tcp any host X.X.X.X eq www
access-list outside_access_in extended permit tcp any host X.X.X.X eq https
access-list outside_access_in extended permit tcp any host X.X.X.X eq telnet
access-list outside_access_in extended permit tcp any host X.X.X.X eq ssh
access-list outside_access_in extended permit tcp any host X.X.X.X eq 8080
access-list REMOTE1 extended permit ip 10.10.1.0 255.255.255.0 192.168.9.0 255.255.255.224
access-list VPN_NAT extended permit ip 10.10.1.0 255.255.255.0 192.168.9.0 255.255.255.224
access-list VPN_NAT extended permit ip 10.10.1.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list VPN_NAT extended permit ip 10.10.1.0 255.255.255.0 10.10.3.96 255.255.255.224
access-list REMOTE2 extended permit ip 10.10.1.0 255.255.255.0 192.168.0.0 255.255.255.0
access-list REMOTEUSERS_splitTunnelAcl standard permit 10.10.1.0 255.255.255.0
pager lines 24
logging buffer-size 1000000
mtu OUTSIDE 1500
mtu INSIDE 1500
ip local pool VPNPOOL 10.10.3.100-10.10.3.125 mask 255.255.255.0
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm506.bin
no asdm history enable
arp timeout 14400
global (OUTSIDE) 1 interface
nat (INSIDE) 0 access-list VPN_NAT
nat (INSIDE) 1 10.10.1.0 255.255.255.0
nat (INSIDE) 1 0.0.0.0 0.0.0.0
static (INSIDE,OUTSIDE) tcp interface www 10.10.1.12 www netmask 255.255.255.255
static (INSIDE,OUTSIDE) tcp interface https 10.10.1.12 https netmask 255.255.255.255
static (INSIDE,OUTSIDE) tcp interface smtp 10.10.1.12 smtp netmask 255.255.255.255
access-group outside_access_in in interface OUTSIDE
route OUTSIDE 0.0.0.0 0.0.0.0 70.164.68.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server RADIUSSERVER protocol radius
aaa-server RADIUSSERVER (INSIDE) host 10.10.1.11
key *****
http server enable 8080
http 0.0.0.0 0.0.0.0 INSIDE
http 0.0.0.0 0.0.0.0 OUTSIDE
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map MYCRYPTOMAP 1 match address REMOTE1
crypto map MYCRYPTOMAP 1 set pfs
crypto map MYCRYPTOMAP 1 set peer X.X.X.X
crypto map MYCRYPTOMAP 1 set transform-set ESP-3DES-SHA
crypto map MYCRYPTOMAP 2 match address REMOTE2
crypto map MYCRYPTOMAP 2 set pfs
crypto map MYCRYPTOMAP 2 set peer X.X.X.X
crypto map MYCRYPTOMAP 2 set transform-set ESP-3DES-MD5
crypto map MYCRYPTOMAP 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map MYCRYPTOMAP interface OUTSIDE
crypto isakmp enable OUTSIDE
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 20
encryption 3des
hash md5
group 2
lifetime 86400
telnet 0.0.0.0 0.0.0.0 OUTSIDE
telnet 0.0.0.0 0.0.0.0 INSIDE
telnet timeout 30
ssh 0.0.0.0 0.0.0.0 OUTSIDE
ssh 0.0.0.0 0.0.0.0 INSIDE
ssh timeout 30
console timeout 0
management-access INSIDE
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy REMOTEUSERS internal
group-policy REMOTEUSERS attributes
dns-server value 10.10.1.11 10.10.1.11
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value REMOTEUSERS_splitTunnelAcl
default-domain value DOMAIN.local
username REMOTEvpn password tN7SYPzaQQsEJFb4 encrypted privilege 0
username REMOTEvpn attributes
vpn-group-policy REMOTEUSERS
tunnel-group X.X.X.X type ipsec-l2l
tunnel-group X.X.X.X ipsec-attributes
pre-shared-key *****
tunnel-group REMOTEUSERS type remote-access
tunnel-group REMOTEUSERS general-attributes
address-pool VPNPOOL
authentication-server-group RADIUSSERVER
default-group-policy REMOTEUSERS
tunnel-group REMOTEUSERS ipsec-attributes
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect netbios
  inspect rsh
  inspect rtsp
  inspect skinny
  inspect esmtp
  inspect sqlnet
  inspect sunrpc
  inspect tftp
  inspect sip
  inspect xdmcp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email callhome@cisco.com
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:ea7d20f6ef65b60d5e296c51405d7d01
: end
Hello Kyle.
Please add the following command:
username xxxx password xxxx privilege #
aaa authentication ssh console LOCAL
Julio
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Hall of Fame Super Silver
Re: Issues SSHing into ASA
Try adding:
514
