Issues with ASA 5505 - Unable to Static NAT for Incoming Connections
I have a new ASA 5505 I've been messing around with. I'm setting it up between two different private IP based networks (two different companies) and with it is a static nat mapping to allow them to access one of our machines. The "public" IP address assigned to the mapping is dedicated only for this purpose. For some reason the Packet-Tracer keeps stopping on the NAT section with an RPF-CHECK, but the config looks ok. Any help is appeciated. The relevent config is posted below. Thanks!
ASA Version 7.2(4)
interface Vlan1
nameif inside
security-level 100
ip address 10.0.10.58 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 10.243.32.2 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
domain-name default.domain.invalid
same-security-traffic permit intra-interface
object-group service rdp tcp
description Remote Desktop Protocol
port-object eq 3389
access-list outside_access_in extended permit icmp any host 10.0.10.25
access-list outside_access_in extended permit tcp any host 10.0.10.25 eq ftp
access-list outside_access_in extended permit tcp any host 10.0.10.25 eq telnet
access-list outside_access_in extended permit tcp any host 10.0.10.25 eq 3389
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
nat-control
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) 10.243.32.10 10.0.10.25 netmask 255.255.255.255
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 10.243.32.1 1
route outside 10.0.0.0 255.255.0.0 10.0.10.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http 10.0.10.0 255.255.255.0 inside
telnet 10.0.10.0 255.255.255.0 inside
telnet timeout 5
ssh 10.0.10.0 255.255.255.0 inside
ssh timeout 5
console timeout 0
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
service-policy global_policy global
: end
Re: Issues with ASA 5505 - Unable to Static NAT for Incoming Con
Output of command: packet-tracer input outside tcp 10.243.32.9 1069 10.0.10.25 3389 detailed
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
Forward Flow based lookup yields rule:
in id=0x3d66778, priority=1, domain=permit, deny=false
hits=3360, user_data=0x0, cs_id=0x0, l3_type=0x8
src mac=0000.0000.0000, mask=0000.0000.0000
dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 3
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in 10.0.10.0 255.255.255.0 inside
Phase: 4
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
in id=0x3da4fc0, priority=12, domain=permit, deny=false
hits=22, user_data=0x3da4f80, cs_id=0x0, flags=0x0, protocol=6
src ip=0.0.0.0, mask=0.0.0.0, port=0
dst ip=10.0.10.25, mask=255.255.255.255, port=3389, dscp=0x0
Phase: 5
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in id=0x3d49bb8, priority=0, domain=permit-ip-option, deny=true
hits=1406, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 6
Type: NAT
Subtype: rpf-check
Result: DROP
Config:
nat-control
match ip inside host 10.0.10.25 outside any
static translation to 10.243.32.10
translate_hits = 195, untranslate_hits = 0
out id=0x3d1c848, priority=5, domain=nat-reverse, deny=false
hits=10, user_data=0x39f0110, cs_id=0x0, flags=0x0, protocol=0
dst ip=10.0.10.25, mask=255.255.255.255, port=0, dscp=0x0
Result:
input-interface: outside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
Hall of Fame Super Blue
Jack
Not entirely clear on what you are trying to do. If you have Natted 10.0.10.25 to 10.243.32.10 then your access-list on your outside interface should be permitting access to 10.243.32.10 and not 10.0.10.25 ie.
change all instances of 10.0.10.25 to 10.243.32.10 in the above acl and then from outside access 10.243.32.10.
If you want to access 10.0.10.25 directly from outside
static (inside,outside) 10.0.10.25 10.0.10.25 netmask 255.255.255.255
Jon
Jon, thanks for the reply. Let me try and explain a little bit more.
The Private (Inside) network is 10.0.10.0/24 and the Public (Outside) network is 10.243.32.0/24. I'm trying to translate the 'public' address of 10.243.32.10 to the private address of 10.0.10.25. As far as I can tell it's setup correctly (this was done via the ASDM but the direct config looks ok too), but yet the Packet-Tracker keeps kicking back an error. I've tried putting a machine on the 'outside' with an IP of 10.243.32.9 and then attempted to RDP to 10.243.32.10 (which should translate back to 10.0.10.25) but it doens't appear to work.
Thanks for the help!
Jack
Can you clarify a bit more. Are you initiating the connection from outside and trying to RDP through to the inside host of 10.0.10.25 ?
If so you cannot leave the config as is and connect to 10.0.10.25 as the destination address. You need to make the destination address 10.243.32.10 and you need to update your access-list.
Could you explain in terms of src and dst IP addresses what connectiokn you are trying to make.
Apologies for being a bit slow :-)
Jon
Yes, I am trying to initiate from the outside to RDP to the inside host. I'll update the ACL's and give it a shot, thx!
Boom, that was it! I don't know why I kept thinking the ACL had to be for the internal IP and not the external. Oh well, at least now I should remember. Thanks!
Thanks for letting me know it worked. Glad to have helped.
Jon
441
