Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Issues with Cisco PIX 515e
So, i am trying just to do the initial setup of a Cisco PIX515e 6.3, and I am hitting a brick wall.
I got the console up, thought that I had everything configured correctly  (Like internal IP and such), but I can't ping to or from, with a  crossover cable from inside/ethernet0 to a PC.
Need some help/advise.
I would also like to get it set up for management via ASDM.
It is a base config, nothing else.
1 REPLY
Typically Inside is Ethernet1 but anyway - I think you need straight cable from inside to PC not xover and then obviously the 6 commands
Nameif
Interface
IP Address
Nat
Global
Route
sh xlate will indicate whether or not your translation is working Nat/Global
sh int will let you know whether your Interfaces are configured correctly
Need to be sure you have different network on each side (inside. outside)
Inside Security = 100
Outside Security = 0
You wont be able to ping to the pix but you should be able to ping from the pix (next hop router, pc, etc)
165
