Juniper to Cisco config conversion issue
I am trying to convert a Juniper to Cisco config, I've used the online tool however I got a lot of errors showing the line that the tool could not convert. I'm working on the below at the moment. is there a way to configure the UUID on an ASA or how do I go about converting these?
could not convert line # 222 from xxxxx.txt
%set service "svc-RPC-MS-SSIS" + ms-rpc uuid 552d076a-cb29-4e44-8b6a-d15e59e2c0af
%ERROR REASON: The protocol defined here is not supported in Cisco service objects, Hence ignoring this line.
1 ACCEPTED SOLUTION
Hi,You would not be able to
You would not be able to filter the DCE-RPC traffic on the basis of a UUID value. This should not be needed to be configured on the ASA device.
You just need to enable the DCERPC inspection.
Thanks and Regards,
Vibhor Amrodia
Thanks and Regards,
Vibhor Amrodia
ThanksI also came across the
I also came across the below config guide in the process.
http://www.cisco.com/c/en/us/td/docs/security/asa/asa82/configuration/guide/config/inspect_mgmt.html#wp1478733
164
