lan connection timeout after ASA reload
hi guys
i have 2 asa 5520 HA .
i have a problem ..
whenever reload this asa my lan users for tcp and udp and icmp  connection is time out , and i force restart users pc , and after restart ok ...
but without restart my connection timeout
please help .
Super Bronze
Hi, Sounds to me like
Sounds to me like Statefull Failover is not in use? I mean that the Active firewall is not passing the connection state information to the Standby firewall so it will have all the up to date information about the connections on the Active unit.
You can always log into the Standby unit and issue the "show conn" command and see if there are any connections listed on that unit, IF not then the unit is not received the state information and when the Failover happens every connection formed through the Active ASA has to be formed again by the users/servers.
You can always share your Failover configuration. You can use the command "show run failover" on both ASAs to list the Failover configuration.
Hope this helps :)
- Jouni
i check failover
i check failover configuration ,,, i think its ok configuration ,,
i attach to u my configuraton
Super Bronze
Hi, It seems to suggest
It seems to suggest somekind of problem between the ASA firewalls as the "comm failure" is listed.
What does the "show failover" command show?
Have you checked both the GigabitEthernet0/2 and GigabitEthernet0/3 links on both units and the network between the ASA units through those interfaces? I think you should go through those interfaces and the network segment between the ASAs and confirm that there is a working Failover/Statefull link between the ASAs.
Did you log into the Standby ASA and check the output of "show conn". If you got connections active through the Active ASA and the Standby ASA does not have anything in its connection table then you have a problem with the Failover setup.
- Jouni
37
