Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Lan-to-Lan Vpn
We have a server in Inside interface it should be accessed for Lan-to-Lan Vpn users not DMZ
we are using ASA 5505
Re: Lan-to-Lan Vpn
It should be stright forward L2L vpn configuration, check this example .
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a00805a87f7.shtml
Rgds
-Jorge
Community Member
Re: Lan-to-Lan Vpn
Jorge,
my concern is i have a server in my inside network which is confidential, we have L2L VPN between my office & counterpart
one of the counterpart want to access this server I don't want to keep this in DMZ because this server is critical so is their any way to do this
Community Member
Re: Lan-to-Lan Vpn
Hi Jorge,
I have completed 50% of the work using the above link but Internet is not working I think for internet it is not able to understand to which gateway it should go because it has two ip address one from VPN pool & other from Local Lan
I want my internet traffic to go via local Lan gateway
Re: Lan-to-Lan Vpn
By default DMZ cannot talk to inside anyway, whats the concern here?
Farrukh
Community Member
Re: Lan-to-Lan Vpn
farrukh,
rgds
Ganesh
Re: Lan-to-Lan Vpn
could you describe your needs in more details to let me help you
thanks
Community Member
Re: Lan-to-Lan Vpn
Hi Marwanshawi,
when I am connected to Remote access VPN not able to access local Lan ie giving printing & Browsing internet using the link which was given earlier I am able to give printing not
Browsing internet I want both to work
pls find the latest FW configuration
Community Member
Re: Lan-to-Lan Vpn
Hi marwanshawi,
their is a Critical server in my inside network my counterpart should access this server, using remote access vpn i don't want to keep the server in DMZ zone is their any other way that remote users can access server in my inside n/w
271
