Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Launch ASDM on outside interface
Dear all values Cisco,
My ASA5520 firewall has inside ip: 172.16.16.1, and outside ip: 192.168.182.1.
I'm in outside network, have ip:10.1.27.0/24, connect to outside interface of firewall.
Servers are in inside network, have ip: 192.168.176.0/24, connect to inside interface of firewall.
Diagram: Servers (192.168.176.0/24) =>Switch=> (inside ip: 172.16.16.1)Firewall(outside ip: 192.168.182.1)=>Switch=>Ouside network (10.1.27.0/24)
Now I can launch ASDM on inside interface (because we have a direct connection to inside switch). And now, I want to launch on outside interface.
Can you help me to config?
Thanks so much,
Dang Nguyen,
Viettel Cambodia Company.
1 ACCEPTED SOLUTION
Re: Launch ASDM on outside interface
All you need to configure is the following:
http 10.1.27.0 255.255.255.0 outside
Hope that helps.
Hope that helps.
Community Member
It works.
Thank you so much.
510
