Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Licensing for high availability firewall solution
Hi security experts,
i have a deployed scenario for ASA5540-BUN-K9 as active/active or active standby, i have been requested to add an SSL anycnnect premium license for 500 users assosiated with mobile license, shall i order one license for both boxes or order two license ( one for each)
I appriciate you suggestions
Everyone's tags (3)
1 ACCEPTED SOLUTION
As long as you run 8.3.1 or higher you will be able to start sharing licenses between failover mates so no need to have one license per box.
Looking for some Networking Assistance?
Contact me directly at jcarvaja@laguiadelnetworking.com
I will fix your problem ASAP.
Cheers,
Julio Carvajal Segura
http://laguiadelnetworking.com
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Cheers,
Julio Carvajal
Community Member
Thank you jcarvaja, i digged in the subject and all refered the same consept.
Re: Licensing for high availability firewall solution
A pleasure to help
Cheers,
Julio Carvajal
Be careful: remote access VPN is not (yet) supported in multi context mode.
Multiple context mode does not support the following features:
?RIP
?OSPFv3. (OSPFv2 is supported.)
?Multicast routing
?Threat Detection
?Unified Communications
?QoS
?Remote access VPN. (Site-to-site VPN is supported.)
95
