jlo
link two networks with same ip network FWSM
hello
I have to link 2 networks with the same IP network.
each IP network is on a séparate FWSM
could you help me for the configuration
nat , global , static
Everyone's tags (1)
Re: link two networks with same ip network FWSM
For starters, here is a document giving all information regarding configuring NAT with FWSM version 3.2:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm32/configuration/guide/cfgnat_f.html
The 2 IP networks that you are referring, do you need complete 2-way communication between them or is it just going to be 1-way communication? if it is going to be 2-way communication, you will meed to statically translate both the networks to different subnets. That is assuming the follwing:
IP network: A/24
FWSM1:
static (in,out) B A netmask 255.255.255.0
FWSM2:
static (in,out) C A netmask 255.255.255.0
Now the IP network A in FWSM1 when trying to access the network behind FWSM2, they will actually need to specify the destination P in the subnet C (because of the static NAT) and also the source IP will get translated to an IP in the subnet B.
When the network behind FWSM2 tries to do the same, the destination will be specified in subnet B and the source IP will get translated to the subnet C.
We need to ensure all the corresponding ACLs and routing reflect these 2 IP subents, B and C.
Again, I am assuming that this is your network requirement and i hope i am correct Do send your detailed requirement if this is not the case and we can recommedations based on that.
All the best!!
Thanks and Regards,
Prapanch
jlo
thank you Prapanch for your answer , I will test it a soon as
possible depend on the FWSM
used
I will inform you if I need more information.
Best regards
jean louis
404
