Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Load Balancing Configuration.
Hi, I have Two ASA Fw and two different ISP leased lines. Now I want to create VPN tunnel site to site with DC and it will work. Its fine. Now I want to use both ASA and both ISP lines will be use for both ASA boxes and I will create the Tunnel. Now if I connect my inside network with both firewall then will it work? I want load balancing between ISP links and load Balancing of VPN tunnel. The configuration is in below:-
FW 1 outside interface 1.1.1.1/24
FW 1 Inside Interface 192.168.12.1/24
FW 2 Outside interface 2.2.2.2/24
FW 2 Inside Interface 192.168.12.2
Now if I assign the gateway 192.168.12.1 on client machines then traffic moves from FW1 and if I use 192.168.12.2 then traffic will move from second Fw. Now I want the traffic will use both interface and 50-50 % traffic could divert. Is it possible then please tell us what shd i do? Thanks.
Community Member
Re: Load Balancing Configuration.
Can anyone respond?
Community Member
Is it possible or not?
Community Member
Well, am i thinking wrong??? Please suggest..
Community Member
Community Member
??? Still waiting response..
268
