Load balancing on ASA
Can i load balance may traffic using single security appliance (ASA)
Thank YOu
2 ACCEPTED SOLUTIONS
Re: Load balancing on ASA
Hi Gents,
but in this case ONLY one ISP is active at the time and the other is idle.
but if u require a load balance between two ISPs, I believe one more router needed to connect to the FW and configure a route-map for load balancing.
could you be more concrete.
What are you going to do?
Suppose i have an ASA in my netowrk, can i terminate two ISPs on my appliance? Also those connetions should provide load balancing in an active-active manner, if one goes down other should carry the entire traffic.. Is it is possible, if so Which among the ASA 5500 series will support these features..?
Hi Gents,
170
