Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Load Balancing.
Hi, One of the drawback in ASA is that it does not support Load Balancing in IP Sec Tunnel and between ISP links. Can we expect this option will be add asap in future by upgrading FW. Thanks
Silver
Re: Load Balancing.
ASA support load balancing. Use this Cisco ASA 5500 Series Adaptive Security Appliances Configuration guide.
http://www.cisco.com/en/US/products/ps6120/tsd_products_support_configure.html
Re: Load Balancing.
From the ASDM online help, this form of clustering only works with Remote Access VPN, not Lan-2-Lan VPN.
I am trying to figure out if it can be implemented on a failover cluster, and if so how to do it.
249
