Logging issue in PIX 6.3
Hi Champs,
I have configured timestamp logging on PIX 506E version 6.3(5). However the output of the log message does not give the timestamp. Let me know if i am missing out of anything. Thanks in advance.
show log
Syslog logging: enabled
Facility: 20
Timestamp logging: enabled
Standby logging: disabled
Console logging: disabled
Monitor logging: disabled
Buffer logging: level debugging, 49191709 messages logged
Trap logging: level informational, 40287472 messages logged
302013: Built outbound TCP connection 16430543 for outside:A.B.C.D/443 (A.B.C.D/443) to inside:172.16.150.99/46579 (A.B.C.D/46579)
302013: Built outbound TCP connection 16430544 for outside:A.B.C.D/443 (A.B.C.D/443) to inside:172.16.150.99/46580 (A.B.C.D/46580)
302013: Built outbound TCP connection 16430545 for outside:A.B.C.D/443 (A.B.C.D/443) to inside:172.16.150.99/46581 (v/46581)
Best Regards,
Manoj
Re: Logging issue in PIX 6.3
Can you post your logging config?
service timestamps log datetime msec should enable time stamping
Hi Collin,
Thanks for the reply, however PIX does not seem to have this sort of command. Below is the output
PIXFW(config)# service timestamps log datetime msec
Usage: service {resetinbound|resetoutside}
PIXFW(Config)(config)#
We do have ASA in other locations, however with only "logging timestamp", it does show the timestamp in the logging. Any further thoughts on this? Thanks again.
Manoj
Manoj-
Sorry about that, I went into a router that I thought was a PIX. After looking in the command reference for 6.3, it states
Specify that syslog messages sent to the syslog server should have a time stamp value on each message.
Looks like you can't time stamp in the local buffer.
http://www.cisco.com/en/US/docs/security/pix/pix63/command/reference/gl.html#wp1028090
148
