Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
loopback interface in ASA or FWSM
Hi experts,
Is it possible to create loopback interfaces in FWSM or ASA firewall
The need is i want a interface command to the firewall as I am facing problem in pinging one interface IP ADDRESS from the other zones.
Thanks in advance
sairam
Re: loopback interface in ASA or FWSM
Sairam,
No - Cisco firewalls do NOT allow for a loopback address. If you are having issues with pinging a certain interface IP address, please be sure that you are pinging the interface closest to the client machine - ie NOT another interface. Unlike a router, the Cisco firewalls do NOT allow you to ping a "far-side" interface. Also, be sure that you have 'icmp permit ' for the relevant interface.
mgs
Community Member
Not entirely true. You can issue the 'management-access inside' command, which will enable you to SSH and issue ping/snmp commands on the inside interface IP eg. from the far-end of a IPsec tunnel configured.
Silver
"Also, be sure that you have 'icmp permit ' for the relevant interface"
This is NOT true. Pix/ASA, by default, will let you ping the interface, unless explicitly dennied.
14557
