Loss of Management interface connectivity on ASA standby unit?
Hi, I have just configured LAN based failover on a pair of ASA5540 firewalls. Prior to failover each unit had its management0/0 interface configured with its own IP address and both are reachable across the management LAN. However, when failover is configured between the pairs we loose ip connectivity to the standby units management0/0 interface. I realise that under a failover configuration the config is replicated from the master to the backup but I would have thought the management interfaces would have been excluded from this therefore still allowing remote management of the stand by unit. Is there any way to configure the standby unit to behave in this way?
147
