Management interface as firewalling interface
I would like to know if I can use management interface as firewalling interface like Outside, Inside and DMZ interfaces instead of just out of band interface.
I have a Cisco ASA.
Thanks a lot, best regards.
Everyone's tags (2)
2 ACCEPTED SOLUTIONS
Re: Management interface as firewalling interface
Yes, it's possible and allow routing on the said interface. Just do a 'no management-only' command under management0/0.
VIP Purple
it depends on the model you have. The old models and 5585-X can do that, but not the newer X-generation:
http://www.cisco.com/en/US/docs/security/asa/asa84/configuration/guide/interface_start.html#wp1324550
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
Don't stop after you've improved your network! Improve the world by lending money to the working poor: http://www.kiva.org/invitedby/karsteni
VIP Purple
Thanks Johnlloyd and Karsten,
I'll configure management interface as a firewalling interface with 'no management-only' command because it is a old device.
Thanks a lot and happy new year.
131
