Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Management interface stoped working after upgrade.
After I have upgraded our ASA 5510 to 8.4.2 I have problem with the management interface.
Our former firmware 8.2.3 had no problem using the management interface as a DMZ zone, but after we upgraded to 8.4.2 we can't make it work.
The interface and the protocol is up, when I type: show interface.
But when I ping the interface from a computer connectet to the interface, nothing happens.
Even the logging shows nothing.
Anyone who can tell me what the problem can be ?
Best regards
Rex Petersen / Denmark
Do you have the command: "management-only" on that management interface?
If you do, please remove it and see if it works.
The management-only command has been removed.
I has been working before (8.2) but after upgrading to 8.4.2 it doesn't work.
// Rex
Can you please share your config?
I don't see any bugs related to management interface in version 8.4.2
I see, I was a little to fast at the keyboard.
It's version 8.4.3(9) and not verson 8.4.2.
// Rex
Sounds like a bug to me, you might want to open a TAC case to get it further troubleshot and open a new bug if it is one.
Re: Management interface stoped working after upgrade.
Hi JeniferYesterday I testet on another ASA5510 with same firmware version, and everything was working ... strange.
Here the interface setup:
interface Ethernet0/0
nameif outside
security-level 0
ip address xx.xxx.xxx.x 255.255.255.224 standby xx.xxx.xxx.x
interface Ethernet0/1
nameif inside
security-level 100
ip address 10.34.4.246 255.255.248.0 standby 10.34.4.245
interface Ethernet0/2
nameif dmz
security-level 20
ip address 10.2.1.1 255.255.255.0
interface Ethernet0/3
description LAN Failover Interface
interface Management0/0
nameif dmz_1
security-level 25
ip address 10.3.1.1 255.255.255.0
boot system disk0:/asa843-k8.bin
Strange indeed.
Maybe try a reload and see if it makes any difference if you have the same on another ASA with same firmware and it works just fine.
355
