Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Management IP on Access Point (BVI5)
Sorry I'm fairly new to APs. I am trying to setup an AP to have the BVI interface on my management Vlan. In this case 5. Here are the configs i have applied.
interface FastEthernet0.5
 encapsulation dot1Q 5 native
 no ip route-cache
 bridge-group 5
 no bridge-group 5 source-learning
 bridge-group 5 spanning-disabled
interface BVI5
 ip address 192.168.5.228 255.255.255.0
 ip helper-address 192.168.10.5
 no ip route-cache
After this I set my truck on the switch for native vlan to be vlan 5 but i still cannot connect to the AP. What am I missing?
1 REPLY
Gold
Hi Austin, Try below
Hi Austin,
Try below configuration.
 no ip route-cache
 bridge-group 1
 no bridge-group 1 source-learning
 bridge-group 1 spanning-disabled
interface BVI1
 no ip route-cache
Your switch port should be trunk with vlan 5 as native vlan. Also you don't need helper address on BVI interface and helper address should be on the L3 interface .i.e the default gateway interface of the AP.
Hope that helps.
Najaf
49
