Management port on ASA5505
I have interfaces defined on the 5505:
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 100
ip address 10.135.70.254 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address x.x.x.x 255.255.255.248
I only need one interface to connect to a single host on the inside (VLAN1) and then connect E0 to a DSL.
Is it possible (are what are the commands required) to take one of the other interfaces and create a Management port on the local office LAN?
Thanks for your help
Everyone's tags (3)
Red
You would need the following for it:
switchport access vlan 3
int vlan 3
nameif management
management-only
no shut
For ssh access:
ssh 0 0 management
crypto key generate rsa modulus 1024
For telnet:
telnet 0 0 management
aaa authentication telnet console LOCAL
For ASDM:
http server enable
http 0 0 management
Here's the doc for it:
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/access_management.html
Hope that helps.
Varun
Thanks, Varun Rao Security Team, Cisco TAC
Re: Management port on ASA5505
Hi Varun,
The ASA is coming back with ' license does not allow for more than 2
nameifs'
Will that matter for ASDM?
Is there another way to define ssh and telnet without using a nameif?
Thanks for your prompt reply and assistance.
Tom Williams
Technical Services Dept.
Ilitch Holdings, Inc.
Office Hours: 7:30am - 4:00 pm Monday -Friday EST
(248) 442-4518
(248) 442-4570 Fax
tom.williams@ilitchholdings.com
Company HELP DESK: 313-471-6329
The information in this email is confidential and may be legally
privileged. It is intended solely for the addressee. Access to this
email by anyone else is unauthorized. If you are not the intended
recipient, any disclosure, copying, distribution or any action taken
or omitted to be taken in reliance on it, is prohibited and may be
unlawful. If you believe that you have received this email in error,
please contact the sender.
To: iholdings ,
Date: 11/08/2011 02:13 PM
Subject: - Re: Management port on ASA5505
Home
created by Varun Rao in Firewalling - View the full discussion
int vlan 3
nameif management
management-only
no shut
For ssh access:
ssh 0 0 management
For telnet:
For ASDM:
http server enable
http 0 0 management
Hope that helps.
Varun
Reply to this message by going to Home
Start a new discussion in Firewalling at Home
6972
