Management Port
I have got ASA 5520. How to use the management port as a normal port on ASA. What are the basic reqirements for that.
- Mero
Management Port
The managment port under regular circunstances will look like this:
interface Management0/0
shutdown
no nameif
no security-level
no ip address
management-only
As you can see the only difference between a regular traffic port and the managment port is the management-only keyword.
So in order to use it as a regular port all you need to do is :
ciscoasa(config)# interface management 0/0
ciscoasa(config-if)# no management-only
And it will look now just like all the other ports,
shutdown
no nameif
no security-level
no ip address
Hope this helps, any other question let me know!!
Do rate helpful posts.
Julio,
Looking for some Networking Assistance? Contact me directly at jcarvaja@laguiadelnetworking.com I will fix your problem ASAP. Cheers, Julio Carvajal Segura http://laguiadelnetworking.com
Management Port
Thanks, I can't see to mark point, why ?
Mero
Management Port
What do you mean by  " I can't see to mark point, why ?"
Julio
424
