Mapping an outside address to an inside address
Hi all,
im getting a problem mapping address on ASA.
I have a outside host (host-A) (10.10.10.2) on same switch that outside ASA interface (10.10.10.1) is plugged. And I have another host (host-B) on DMZ (172.16.2.2).
I wanna map the outside address 10.10.10.2 to inside address 172.16.2.2.
So, I changed the outside host ip address to 10.10.10.3 (host-A) and put this command on ASA:
static (DMZ,WAN) 10.10.10.2 172.16.2.2 netmask 255.255.255.255
but the packets to 10.10.10.2 still go to the (host-A), not to host-B on DMZ. It seems ASA is not mapping the address properly.
What should I do?
Re: Mapping an outside address to an inside address
hi,
try the following commands on the ASA:
clear xlate
clear arp-cache
And also do a "clear arp" on the external switch.
Hope this helps.
dhananjoy
I put this command and its still not working.
The ASA doesn't receive the packets.
Thks
208
