Marking Voice traffic on ASA5505 for Prioritization
Is there a way to mark voice traffic with dscp values on an ASA5505? Specifically, I need to mark voice traffic for prioritization from a Cisco 7960 phone that is directly connected to one of the POE ports on the ASA5505. I know how to prioritize dscp traffic on the ASA, but I need to be able to mark the voice signal and rtp traffic between the phone and the 3des vpn connected call managers and other voice networks.
Can the marking be done on the ASA?
Below is a configuration example for prioritizing dscp traffic, and below that the commands I wish existed for marking the traffic:
ASA commands to prioritize the dscp marked packets:
class-map voip-sig
match dscp cs3
class-map voip-rtp
match dscp af31
policy-map voip-qos-policy
class voip-sig
priority
class voip-rtp
priority
service-policy voip-qos-policy interface outside
The "set dscp xx" command that I wish existed on the ASA's:
policy-map voip-qos
class voip-signal
match access-list voip-signal-qos
set dscp cs3
class voip-rtp
match access-list voip-rtp-qos
set dscp ef
access-list voip-signal-qos remark VoIP Signal traffic
access-list voip-signal-qos extended permit tcp 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0 eq 2000
access-list voip-rtp-qos remark VoIP RTP Data traffic
access-list voip-rtp-qos permit udp 10.1.1.0 255.255.255.0 10.1.2.0 255.255.255.0 range 16384 32767
1 REPLY
Re: Marking Voice traffic on ASA5505 for Prioritization
Any feedback on this? Looks like I will be opening another tac case. :(
698
