Silver
maximum 1-to-1 static NAT alllow on Pix 535 with 8.0(3) code
Pix 535 with 1GB RAM and running version 8.0(3). I would like to do this:
static (i,o) 1.x.x.1 10.x.x.1 netmask 255.255.255.255
static (i,o) 1.1.1.2 10.x.x.2 netmask 255.255.255.255
static (i,o) 1.x.x.x 10.x.x.x netmask 255.255.255.255
How many static 1-to-1 NAT that the Pix535 can handle before it can't take anymore lines like this in the configuration?
Thanks.
Re: maximum 1-to-1 static NAT alllow on Pix 535 with 8.0(3) code
This is the only statistics page I know of, and does not mention this ( I think ):
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/specs.html#wp1164265
This command does not detail this either:
http://www.cisco.com/en/US/docs/security/asa/asa80/command/reference/s4.html#wp1400647
Farrukh
Silver
anyone know where I can find solution to this question? Thanks.
I have not yet if any come across a doc indicating a limitation for one to one nat statements, I hate guessing but will make exception, in this case I would think the limitation of 1-t-1 nat statement configuration lines could be associated with the config file size limitation of the device, if Im not mistaken I have read somewhere config file size limitations on some firewalls versions but not sure which, this is just an opinion.
Rgds
-Jorge
193
