MIB issue ASA 5510
I'm trying to query a mib for the asa to show me what IP peer is connected on a tunnel.
When I do a mib walk on the 5510 8.2(1) none of the OID'S for these values show up, although they should be supported.
Ie cikepeerentry or crasusername OIDs.
I would have expected the ASA to support all the OIDS that are listed in the SNMP object navigator under that IOS?
Any advice would be great.
Sam
Re: MIB issue ASA 5510
ASA is not IOS, it's not the same supported list of mibs.
You can only have the following :
ftp://ftp-sj.cisco.com/pub/mibs/supportlists/asa/asa-supportlist.html
crasUsername is in the CISCO-REMOTE-ACCESS-MONITOR-MIB listed among the MIBs on that page, but says OID not supported when I try to walk that part of the MIB.  I have the same problem because I can get everything (Remote IP, Local IP, VPN Group) but the user name for VPN sessions.  With the 3030 VPN Concentrator it was part of the ALTIGA-SESSION-STATS-MIB.  Since we've moved our Cisco VPN Client sessions to the ASA we can't monitor those using our SNMP management system.  You can see the session information from a command line session on the ASA (show vpn-sessiondb remote), or from the ASDM interface, but that's doesn't help the NOC.
1290
