Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Missing switchport monitor on ASA
I need to use switchport monitor  command on my ASA 5515X  8.6(1) but I do not see that command under interface.
ASA(config-if)#interface gigabitEthernet 0/1
ASA(config-if)# s?
interface mode commands/options:
  security-level     shutdown    speed    split-horizon
  summary-address
configure mode commands/options:
  same-security-traffic    service        service-policy    setup
  sla                      smtp-server    smtps             snmp
  snmp-map                 snmp-server    ssh               ssl
  sunrpc-server            sysopt
exec mode commands/options:
  session      show     shun    ssh
  sw-module  *s=show
Licensed features for this platform:
Maximum Physical Interfaces       : Unlimited      perpetual
Maximum VLANs                     : 100            perpetual
Inside Hosts                      : Unlimited      perpetual
Failover                          : Active/Active  perpetual
VPN-DES                           : Enabled        perpetual
VPN-3DES-AES                      : Enabled        perpetual
Security Contexts                 : 2              perpetual
GTP/GPRS                          : Disabled       perpetual
AnyConnect Premium Peers          : 2              perpetual
AnyConnect Essentials             : Disabled       perpetual
Other VPN Peers                   : 250            perpetual
Total VPN Peers                   : 250            perpetual
Shared License                    : Disabled       perpetual
AnyConnect for Mobile             : Disabled       perpetual
AnyConnect for Cisco VPN Phone    : Disabled       perpetual
Advanced Endpoint Assessment      : Disabled       perpetual
UC Phone Proxy Sessions           : 2              perpetual
Total UC Proxy Sessions           : 2              perpetual
Botnet Traffic Filter             : Disabled       perpetual
Intercompany Media Engine         : Disabled       perpetual
IPS Module                        : Disabled       perpetual
This platform has an ASA 5515 Security Plus license.
Could you advise why I do not see that command?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi,This command is supported
This command is supported on models with built-in switch (like 5505) but not on higher end models.
From cisco Docs:
For models with a built-in switch, such as the ASA 5505 adaptive security appliance, use the switchport monitor command in interface configuration mode to enable SPAN, also known as switch port monitoring.
hth
MS
1 REPLY
From cisco Docs:
hth
MS
213
