Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Community Member
Monitor connections to DMZ port on ASA 5505?
I hope this is in the right forum.
How do I monitor connections to the DMZ port on our ASA 5505 (via ASDM 5.2)? We have a WAP connected to it and it's intermittently dropping connections.
Thanks!
Try using below commands..
logging enable
logging asdm informational
hth
MS
Community Member
^ is there a way to tell if this has already been done (by using ASDM)? i didn't originally set it up and i can remote into a computer and run ASDM but it takes a while to drive there (and connect to the ASA and run the command you provided).
357
