Step-by-Step Configuration and Troubleshooting Best Practices for the NGFW, NGIPS and AMP Technologies A Visual Guide to the Cisco Firepower Threat Defense (FTD)
Monitor site to site VPNS
I have several site to site VPN's that come from different company's and are allowed access to some subnets on my company's DMZ.  They are working ok and I can view the status of them in Cisco ASDM under:
Monitoring
VPN statistics
Is their any way I can put this on my snmpc server which polls routers/switches on the network or is their a better way of monitoring these and get alerts etc
regards,
Kevin
2 ACCEPTED SOLUTIONS
Hall of Fame Super Silver
The count of them can be
The count of them can be polled with SNMP.
I don't have the PRTG server in front of me right now to call up the OIDs but I've seen this done using that tool. The same thing could be done using any SNMP poller.
How about an alert that polls
How about an alert that polls you when an IP address on the other side of the tunnel goes down?
I will try this as I have
I will try this as I have found the OIDs on the snmpc server.  Thanks, Kevin
Yes - this works ok if I have
Yes - this works ok if I have access to both sides of the tunnel.  But in some of my VPN's they are coming from a supplier and I don't have access to that information - but still in theory this does work ok.
Kevin
54
